SOURCE: i couldnt find a driver for VGP-BMS33 mouse
Unfortunatly SONY do not supply a download for this accessory as apparently something in the driver pack is copyright. Anyhow to get a driver you must contact Sony and ask for a copy of the original CD Link HERE: http://support.vaio.sony.co.uk/contacts/contacts.asp?site=voe_en_GB_cons&tp=vaio&cm=e-support
SOURCE: Find a driver for my Sony bluetooth laser mouse VGP 33
Here are the drivers for wireless vgp 30, distributed in US. They should work on 33 as well
SOURCE: Sony VGP BMS33 Mouse Driver
There are no drivers for this mouse available.
You can try reseting the mouse by: ( I am going to assume you already checked the batteries are OK)
1. Turn the mouse off.
2. Take out out battery.
3. With the battery out, turn it ON.
4. With the battery off, press the connect button.
5. Put the battery back on WHILE pressing the connect button.
If your bluethooth is able to detect the mouse but cannot connect, then it is most likely a problem with the HID registration.
For this:
1. Go to my computer and right click.
2. Go to properties
3. Under Hardware, click on devise manager.
4. Make sure you dont have an exclamation mark under HID devices, if you do simply update the driver and this hsould do the trick. You might get a Microsoft Warning, just ignore it.
Hope this helps!
SOURCE: Sony VGP-WKB5 VAIO Wireless Keyboard unable to connect
Disconnect all devices from your PC including usb mouse and power adaptor.
Press power button and hold it for 20 seconds.
This will statically discharge teh PC. THen take out batteries from the keyboard and pres connect button to discharge keyboard.
When this is done connect pc to the mains and turn it on
Put batteries into keyboard and try to connect.
Press connect button on the pc first and then within few seconds press connect button on the keyboard.
Please leave your feedback if issue is solved or you need futher assistance
