Garden Logo
R
Roy Edwards Posted on May 30, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 17 Horsepower Koler Engine on a Zero Turn Mower and fuel is getting into the Crankcase. Can it be that the fuel pump is causing the problem?
Jason
Level 2:
  • Expert 218 Answers
  • Posted on May 30, 2017
Jason
Expert
Level 2:
Answers
218
Questions
Helped
133680
Points
520
It sounds like your carburetor is dumping the fuel. I would rebuild it or replace it first.
John deere model FC420
Specifications
Engine HD45
Engine Model Number(Kawasaki FC420V
Horsepower (10.5 kW (14 hp)
Displacement (423 cc (25.8 cu.in.)
Crankcase Capacity w/o oil filter (1.3 L (1.4 qt.)
Crankcase Capacity with oil filter (1.6 L (1.7 qt.)
Spark Plug-Gap (0.64 mm (0.025 in.)
Spark Plug-Torque (20 N·m (15 lb-ft.)
Cylinders (One
Stroke/Cycle (Four
Lubrication (Full-Pressure
Oil Filter (Standard Single Element
Air Cleaner (Dual Stage
Engine HD75
Engine Model Numbe(Kawasaki FC540V
Horsepower (12.7 kW (17 hp)
Displacement (535 cc (32.6 cu.in.)
Crankcase Capacity w/o oil filter (1.6 L (1.7 qt.)
Crankcase Capacity with oil filter (1.9 L (2.0 qt.)
Cylinders (One
Stroke/Cycle (Four
Fuel System
Fuel (See Fuel in the Service Miscellaneous section
Fuel Filter (Single Stage, 60 Micron
Fuel Pump (Vacuum Operated-Diaphragm
Fuel Delivery (Gravity Feed to Fuel Pump)
Fuel Tank Capacity (19 L (5.0 gal.)
Drive Train Mower Deck (36-inch)
Blades (2
Blade Bolt Torque (81 N·m (60 lb-ft.)
Cutting Heights (25-114 mm (1-41/2 in.)
Weight (86.7 Kg (191 lb)
Overall Width (chute up) (927 mm (36.5 in.)
Mower Deck (48-inch)
Blades (3
Blade Bolt Torque (68 N·m (50 lb-ft.)
Cutting Heights (25-127 mm (1-5 in.)
Weight (83.6 Kg (184 lb)
Overall Width (chute up) (1308 mm (51.5 in
ower Deck (54-inch)
Blades (3
Cutting Heights (25-127mm (1-5 in.)
Weight (86.7 Kg (187 lb)
Overall Width (chute up) (1460 mm (57.5 in.)
Recommended Lubricants
Engine Oil (John Deere PLUS-4
Grease (John Deere MOLY HIGH Temperature EP
Transmission Oil (HY-GARD-J20C (TURF-GARD-SAE10W-30 (PLUS-4-SAE10W-30 (TORQ-GARD SUPREME-SAE30
(Specifications and design subject to change without notice.)
On the Zero turn mower , how do you relieve the air in the pump lines after replacing a bad pump . Please advise.
How To Release Pressure From Fuel Lines - YouTube
? 0:51
www.youtube.com/watch?v=6oo9zlTMPOQ
Oct 15, 2009 - Uploaded by YeechBlitz
See a demonstration on how to release the pressure from fuellines of a 1997-2000 ... in the tank, but do not let the air out, so pressure can build up in there. ... Diesels is where you want to be extra careful, the injector pump to ...
5900748 Snapper Zero Turn Mower - Hammerwall
www.hammerwall.com/.../Snapper/.../5900748/Snapper%20Zero%20Tur...
Back To Snapper Tractors-Riding-Lawnmowers Model: 5900748 Snapper Zero ......Reinstall each mower blade with the air lifts pointing up towards the mower deck ... The fuel filter is located in the fuel line betweenthe fuel tank and fuel pump . .....TROUBLESHOOTINGTHE RIDER PROBLEM CAUSE REMEDY Enginewill ...
Why is oil leaking around the fuel pump and out the oil filler tube?
STOP>>>>>Check your oil, I believe you will find it over full and have the smell of gas to it. If this is the case, your float is not working in your carb and the fuel is filling your crankcase.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/steve_f5a6ca85b5d1ffc9
Why is oil leaking from the fuel pump and oil filler tube?
Check the float in the carburetor and the fuel shut off solenoid on the carburetor. Fuel can get in the crankcase when the engine is not running and push oil out the filler tube.
1helpful
2answers
Husqvarna with Kohler twin has crankcase FULL of gasoline. WHY?
It's highly possible that it's either in the carburetor (something holding the float down allowing fuel to fill the carburetor and over flow draining into the cylinders, possible porous float or debris between needle and seat.) Or it could be drawing or sucking it in through the fuel pump vacuum line between the engine and fuel pump. I would be looking into these two areas.
I have a 2005 Dixon zero turn mower the motor is hard to turn over but once it starts turning it turns fine when the motor starts it will only idle and not accelerate it has a 14.5 hp Briggs and Stratton...
sounds lie it's starving for gas.
Does this engine have a fuel pump or is the gas gravity fed???
Some engines this size do have fuel pumps.
I'd also take the bowl off the carburetor and check the Jet.
Need diagram for mower belt deck for Craftsman ZTS 7500 42'
need a mowing deck diagram for 2008 42 inch 21 horsepower zero turn
Top Garden Experts
Jay Finke
Jay Finke
john h
