This mistake code, as a rule, shows up when your encoder strip gets chaotic. You may defy various printing bungles if the blunder isn't fixed on schedule. You may run over other mistake messages identified with this blunder code. As a result of this blunder, you may get the accompanying mistake messages also:
-Brother Printer Unable To Print 8f
-Incapable of Scan
-Brother Printer Unable to Clean and a lot more printer usefulness issues.
*Solutions to Troubleshoot Brother Printer Error 48
-SOLUTION 1: Look for a Brother Printer Paper Jam or Paper
-SOLUTION 2: Cleaning of the Encoder Strip
If facing any problem related to printer please visit us
Look inside the printer using some light. If you do not find anything like piece of paper, or paper clip, etc then you most likely have a faulty printhead.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/alex_22751bbefa74c3d0
SOURCE: Help needed
If you open up the cover there are two little covers in there lift the long one out. It should have a thick white wire in it make sure it is plugged in. I had the same problem for two days and finally figured it out hope it works.
SOURCE: machine error 48 or init unable 48
There are several issues that pertain to this code, including a service update. If your printer is still under warranty – visit your local ASC, find one here, this issue is covered! First off, the Service Update, the encoder strip needs to be cleaned with a lint free cloth. The encoder strip is responsible for relaying the position of the print head to the main pcb. If the encoder strip gets dirty, many different problems can occur. The encoder strip is exposed, which allows grease, paper dust, finger prints, ink, etc. to get onto the encoder strip. (The white strip when you open the scanner cover)
If the machine still errors, the encoder strip needs to be replaced – Part Number LS4467001
If the machine still errors, replace the carriage PCB assembly – Part Number LS6543001
If the machine still errors, replace the Printhead – Part Number LK3211001
If the machine still errors, replace the Main PCB assembly – Part Number LT0284011
THANK YOU FOR USING FIXYA! – DON’T FORGET TO RATE OUR SERVICE!
SOURCE: init unable 48 for brother
Manual says that it is a mechanical error, see page 65:
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002526/cv_dcp375w_asaoceeng_usr_lx1485040.pdf
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: printer brother DCP-195C how i can
I have brother DCP-195C but having problem with no power.. pls help me to solve it..
