Televison & Video Logo
Bakari Worthy Posted on May 29, 2017
I have a HP PL5060N that was given to me. It comes on but has no picture, sound works. DO i need to replace the Main video board, or the YSUS board.
My research says it could be the YSUS board so i am not sure what to order.
5 Related Answers
Anonymous
  • 160 Answers
  • Posted on Aug 12, 2010
SOURCE: I just replaced the ysus board. I have sound but
Hello.
Put your old board back - if TV will turn on and dark picture will still present - then you just have purchased defective board. If even old board won't bring picture back - probably Plasma Panel couldn't take it anymore and died.
regards.
Russ.
vinceisaac
francoise cleofas
  • 2432 Answers
  • Posted on Aug 09, 2011
SOURCE: Hello, I have an HP PL5060N, that I am working on.
hi sir have you been check already the speaker as will as the connector. then check normal voltage for audio, if it is normal then the problem is with in audio processor or at the amplifier. now try to disconnect the connector going to the Y sustain then turn on the unit observed if no sqealing sound.now if the sound was gone the problem is with in the Y sustain board check leak or bulging capacitors as will as the high voltage transformer if their is a loose contact. replaced capacitors with same rating a panasonic FM or FC series much better. good luck feel free to ask further question good day thanks.
Anonymous
  • 1238 Answers
  • Posted on Aug 10, 2011
SOURCE: PL5060n Just replaced Ysus board
Good day!!!!
please try to replaced also the y-buffer board to have a great picture...
normally when the y-sustain is bad sometimes the y-buffer got damage also...
just add a comment to let me know what happen and I give another solution...
Thanks for using fixya...
Have a nice day!!!
gopakumarg43
  • 76851 Answers
  • Posted on Feb 08, 2014
SOURCE: I heard a loud pop and my picture went out. Found a blown fuse on the Ysus and hear a ticking coming from the power board.
Y-Sustain IC short. Replace this board as card basis. If you wish to get some details; check the site linked here.Viewing it in "Mosaic" will make surf easy.
Bryan Smith
  • 373 Answers
  • Posted on Dec 03, 2014
SOURCE: I have a 3 year old LG 50pt350 plasma tv. I just
Many LED TVs and other electronics have bad capacitors on their power supply boards. You can visually inspect them by opening the TV and looking for capacitors with bulging tops. If tou see any, replace them all in the power board section. Check to see if your TV is still under warranty first though.
1helpful
My LGPA4500-UF plasma tv has no picture only a clicking sound. I changed out the ZSUS Board same problem.Could it be YSUS or Power source unit?
hi i'd check the buffer boards that connect to the ysus board for white dots if there are some, the buffers need replacing and i'd replace the ysus as well thanks
shaun
Plasma HP PL5060N ticking noise and flashing. Which board need to replace YSUS or ZSUS?
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Every time I start my vizio it shuts off. no picture.
Are you OK to open and work on it?
There are several possibilities and you'll need to be disconnecting and reconnecting boards to be able to detect it for sure.
Do you have a multimeter? It would come handy to be able to check for shorts.
I've serviced hundreds of those and can most certainly guide you through it, but I need to know what can I work with.
BTW you can find some related articles here:
http://blog.coppelltvrepair.com/2010/02/y-sustain-6870qyc004b-6871qyh039a.html
(this is the most likely candidate for your case)
http://blog.coppelltvrepair.com/2010/02/hp-pl5060n-problem-6870qzc004a.html
(this is the second most likely candidate for your case)
http://blog.coppelltvrepair.com/2010/09/lg-50pc3d-with-negative-image-on-screen.html
(not related to your case, but related to the YSUS board services)
http://blog.coppelltvrepair.com/2011/05/should-i-replace-repair-one-or-both.html
(A question you are very likely to face yourself)
it is also possible that your power board may have burned - individually or as a result of a failed YSUS board; this is more rare in those TVs than the above described failures of sustain boards, but it's not not out of question and should be and will be considered.
Last but not least...it *may* be almost anything else.
I am just telling you likelyhood based on experience servicing probably a few hundreds of those.
Hope it helps....if it does, rate it accordingly please...we enjoy positive feedback.
Thanks!
Picture went black but you could still hear the movie
Hi- My PL4260N stopped working after about three years, the audio worked but no video at all. The TV worked fine until one day...no more picture.
I found out that the YSUS and ZSUS boards in the TC fail alot...BUT you can get new or repaired ones off of EBAY...
First check for failed components (burned, loose, bulging, etc.) if nothing obvious is failed then check the fuses on the YSUS, ZSUS, and power supply boards...usually if a board has a blown fuse the board needs to be replaced...get the part number and search it in Google and eBay and you will find options for replace/repair.
Mine had a blown fuse on the YSUS board...I got it fixed for $75 through coppell TV (they are on Ebay)....
Now my TV works fine again!
Good luck.
2helpful
2answers
My hp plasma tv lost it's picture. Audio works fine. Work are some causes of this?
The T-con board, the board that sit right in the middle of the center LCD panel . That board is dying. try websites like shopjimmy.com, Ebay.com to buy a refurbish T-con board for replacement.
Maxent plasma tv no picture or sound
Check and replace that board. Just visit the site linked here. Y Sustain board faults and symptoms of plasma display is given in details. http://electronicshelponline.blogspot.com/
While checking Vscan voltages on my LG du-42px12x picture died.
I have the same problem the pic went out but have sound. where do i go to get the Yboard? do i need a special number off of it or something? I took it to repair shop and he said it would be like 500 dollarss to repair. but i see all kind of yboards on ebay for like 150?? how do I know what one to buy?
2answers
My picture is flickering but there the sound is
Did you try buying a new HDMI cable? You can also try some of the solutions in the post called "Hp 42 plasma tv cptoh 0602 I get sound but no picture."
No picture or sound.
Replace ysus board!!
Check all supply rails before replacing,
Cheers
Top HP Televison & Video Experts
 Mikey
Mikey
Stan Ford
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
