Hello wallbridge,
To update your garmin nuvi is free. All you need to do is to first downlad the webupdater on to a PC then you go to the webupdater software on your pc and then you connect your garmin nuvi to the PC.
Select the updates of your choice, whether the map updates or software update. It will bring up the latest update for you. Then you select the update and it will be installed on your garmin nuvi for you.
You cn download the webupdater from the garmin nuvi website. www.garmin.com
Or you can go to www.garmin.com, when the page is fully loaded, go the the support link, a slide will pop out, then you select what you want to update there, either the maps or software, then follow the rest of the instructions from there.
Would be glad to know if this information helped you.
All the best.
Elect_Comp
After registering the garmin nuvi, you will be able to download free maps. Depending on the type of map you want to download. Registration is free and garmin nuvi do not charge you for any map you update. Update is absolutely free.
Hello. You can try the nüMaps Guarantee. It will give you free map update for 60 days after registering your unit. Check it out here. Now, you can get map updates from Garmin only as there are no longer free maps except if offered.
First, check to make sure the map file is there. The file name is gmapprom.img. It's located in the Garmin directory. It should be 1GB in size. To do this you need to connect the Nuvi to a PC with a USB cable.
Next, please tell me what year of map you have on your unit, 2009, 2010, etc.
Them, email me your units internal serial number. Its a 10 digit number (not the number on the outside). The number starts with a "3" and can be found by pressing the tools button, then system and then "about".
I find that hard to be true. The manufactuer just came out with updates for the Nuvi 3xx and 6xx this month (Aug 09) and those models are older than your Nuvi 205W. When you mean updates are you referring to firmware or maps? Either way, even the discontinued models are still being supported with firmware & map updates.
If you are having trouble getting your unit updated, please let me know and I can help you with this.
Delete all the vehicles and voices that you don't use as well.
Btw, beware that the "City Navigator Lower 49 States+PR NT 2010.10, Deluxe, Apr 09" for nuvi 200/205 is BUSTED, it probably will not work (I just spent 2+hrs on the phone with garmin tech support to fix it.) Search these forums for "nuvi 205 no detailed maps" for more details.
