Computers & Internet Logo
R
Rakesh Kumar Posted on May 27, 2017
Lg 17 crt moniter no make the eht - LG Computers & Internet
5 Related Answers
Anonymous
  • Posted on Jul 03, 2007
SOURCE: Samsung SyncMaster 793MB 17 in.CRT Troubleshooting
remove EHT wire and clean that area with spirit or isopropal alchohal. dry it . if neccessary replace the EHT cap. apply JELLY (like vasiline)at EHT cap and at CRT where EHT placed. if possible spray the ecrilic.dry it and it will never gives trouble like this.
Anonymous
  • 4234 Answers
  • Posted on May 07, 2008
SOURCE: 2SC5589 in LG 17" CRT Monitor
This transistor is manufactured by Toshiba and is only available through Gateway.
Dan
Buddy Mcsparrin
  • 1684 Answers
  • Posted on Jul 14, 2009
SOURCE: what component failed in my 17"CRT 753s model samsung moniter?
Your vertical deflector circuit is going out. This is really not economical to repair, the chip alone is $12-15 plus if you have any other parts in the circuit going out plus labor. You can pickup 17" CRT monitors for less than $15 from goodwill or craigslist.
Sorry to say but I think its time to retire your 753s
Buddy
Corporate Computer
Anonymous
  • 10 Answers
  • Posted on Aug 25, 2009
SOURCE: 700e Lg crt monitor problam power on eht on but not display
The normal crt monitor have a demo display when you unplug the vga cable to PC like this image below.. fd6b6b9.jpg
Note:
If the crt monitor green LED light steady and heater beam have light, the horinzontal and High Voltage supplied to tube is completely good. If you encountered this problem just focus on video section of crt monitor. But before you start... find the flyback transformer behind this they have two controls screen & focus. After you found it plugin the monitor use plastic precision or small screw philip driver for safety to high voltage at horizontal area choose screen control rotate it to clockwise direction follow this....
5b5166c.jpg If the display responses or from dim to lighter 100% you have a problem to ABL find this at the bottom of horinzontal section near at flyback transformer pins trace the line of ABL for dried solder, open resistor if nothing happen find the Video IC at chroma section and replace it. follow this...
3c6e89c.jpg For LG & Redfox you found LM1269NA Visit this site for seaching semiconductor matches www.alldatasheet.com Good luck.
Check this site for searching semiconductor
Silverdragon
electronic & computer repair& servicre
  • 12061 Answers
  • Posted on May 23, 2010
SOURCE: LG Studiowork, CRT Moniter, picture not display on screen
http://www.eserviceinfo.com/index.php?what=search2&searchstring=studioworks+700s+(cb777f)
Service and repair manual above.
Lg 700E model CRT moniter uneven shapes
http://www.shvoong.com/how-to/computers-and-internet/2029464-lg-700e-crt-monitor-settings/
EHT FAILURE
YOUR LG 17" MONITOR S.W 775N EHT NO ( 6174Z-1012B )
( AE28JJ )
2answers
Blinking Screen?
it is monitor problem,it should be EHT problem
Moniter problem
first thing it is not necessary to replace eht when there is no raster.
  • you please go as per procedure.
  • check output from power supply
  • if is ok check horizontal section
  • if it is ok or eht ok then check for heater glowing
  • check video output supply & print open
  • check g2 voltage on crt base.
  • check crt base for loose.
  • check for signal coming to video output ckt.
  • for ckt you can refer modern color monitor ckts volume 1&2.
  • available in india.
  • hope this will help.
  • good luck
  • be in contact with me unless it is rectified.
Top LG Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
