SOURCE: Preylahong NEC MT830+need help to reset new lamp
After replacing lamp in MT-830(NEC) press and hold "on" button for 10 seconds to reset lamp hours. If projector has beyond 2100 hours press the "off" button for 10 second.
SOURCE: Resetting Lamp Hours Procedure On Nec-MT-1075
Hi - You can download the manual by clicking the link underlined in blue below:
Nec-MT-1075
See page E-55:
As in the note replacing the lamp automatically clears the lamp hours.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
SOURCE: Reset lamp hr feature on NEC projector
Give up chuck. It is futile. Actually looking for NEC number right now. for support.
SOURCE: NEC VT 480, replaced new lamp ,still low brightness.
if you remove the lamp, inside the lamp housing you will see a refraction (fly-eye) lens. these evenly distribute the lamp light. the one on the other side from the one you see (there are always 2 lenses) is probably burnt and needs replacing (a common problem with lcd projectors). you will have to send it in to nec. in many of their projectors, both lenses are in one assembly.
SOURCE: I exchanged a lamp in
Power up the projector and then hold down the HELP button on the remote control for 10 seconds to reset the lamp hours to zero.
