SOURCE: Simpletech 160GB external drive
since when did this problem start?
have you checked the cables?
SOURCE: Drivers for simple 160gb
To access an external USB drive in Windows 98, you need to be using Windows 98 SE (Second Edition). Before SE, there was no USB support in Windows 98.
Even then, you will probably not be able to access the full 160Gb of the hard drive. Your best bet is to upgrade to a newer version of Windows, such as 2000, or XP. I know that, depending on your hardware, that might be asking a little too much, but to support all these more modern gadgets, you're going to have to give up on 98 eventually.
Hope this helps.
SOURCE: SIMPLETECH 160GB EXTERNAL HARD DRIVE
Is this compatible with vista?
Ensure all the plugs are right and try on a different pc to see if its the pcs or the exhdd's problem
