I need to get a picture of were the wires attach so i can fix my sylvania bluetooth speaker model SP606BT
SOURCE: battery sparks badly when trying to attach a battery charger
As long as your attaching red to + and black to - you'll be fine. If you don't want sparks don't turn on your charger until after you connect the wires. Be sure to remove the negative cable to your car before charging or you can damage the computer in the vehicle.
SOURCE: need to reattach the oven door
most doors lift off. there should be some stops on the hinge .set them before remmoving door . but you have already got the door off so you will have to reset the hinge lever till the stop will hold then insert the hinge into slot and fold the door down . release the stops and door work work properly . mm .
SOURCE: where can i buy another battery charger for my 7" sylvania netbook?
I have 2 suggestions:
www.batterybiz.com
www.theupgradeplace.com
All have blown strangely enough?? You have a short circuit, quit installing higher rated fuses find the shorted wire. You are going to start an electrical fire if you keep this up.
