SOURCE: new bowl & hook hobart d300
There is a website called onesharpstore.com, It carries parts for the hobart 30 quart mixer. I specifically saw the bowl and hook attachments as well as others like beaters and a cheese and vegetable grater. Hope this helps. And if you sign up I think you can even request a full catalog for your machine.
SOURCE: older hobart kitchen aide Supera by hobart KDH7A
If i remember correctly, a KD7 was built in the 70's or early 80's, we used to service them before being sold to Inglis. Seeing it uses the same water solenoids to fill, and asuming it is filling ok, I would suspect worn arms and hubs. If it doesn't fill completely, the fill valve coils may be opening when they get hot from the water flow. The fact that you need a new rack would indicate wear thhoughout and may be too old to justify repair. Find your local Inglis dealer to check on parts availability.
SOURCE: hobart 1962 comercial dishwasher .Needs parts
www.hobartservice.com Click on "locate an office" and type in your zip.
SOURCE: new frigidaire dishwasher won't fill with water
Underneath the front of the unit just behind the door, you will find a small black tab type block with two pink wires. That is a disconnect to the water intake. If the tab is up, place the tab back in the clear plastic holder. This will turn the power back on to the inlet valve.
