SOURCE: Need help with harmony 520 remote
1. Remove batteries
2. Hold "2" button down.
3. While holding "2" button down, reinsert batteries
4. Continue to hold "2" button down until remote exits safe mode.
SOURCE: How to reprogram Harmony 520 to a replacement DVD/VCR?
You need the Harmony software on your computer that is available at www.logitech.com. You will then have to connect your remote to the computer to change your configuration using said software. You may need to start from scratch if you don't know the username and password for your Harmony account. The software will step you through setting up your remote it's fairly simple.
SOURCE: harmony 520 update problems says
update your Logitech harmony software, then log in and update your firmware.
Also, if this continues, try using another USB cable or connecting at the back of the computer where the usb connection is direct to the motherboard
SOURCE: Blank screen on logitech harmony 520 remote
If the firmware didnt help, then it is a hardware issue. You probably got water in the battery compartment or something.
Anyway you should call Logitech support for a warranty claim. Or, you can do it by taking a look at the following link:
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=12657
Hope I was able to help!
