I have done everything that Xbox has told me to do to get back my info even deleting my profile and re down loading it and I am ready to take my x box 360 to Microsoft plaza in Redmond and throw it thru the game test building
SOURCE: corrupted profile after taking out hard drive xbox
http://www.xbox.com/en-US/hardware/x/xbox360prosystem/gameonthego.htm
SOURCE: saved games on xbox 360 hard drive
its not the account just the hard drive. make a new xbox live account.
SOURCE: How can I recover a profile w/ game saves on xbox 360 hard drive?
you cant recover the saves only the profile
SOURCE: whenever i try to load
Sounds like your hard drive or memory chip that has a corrupt file that has affected it. Normally problems like this are only isolated to a specific game's save game files. If you have never had your console connected to xbox live then none of their updates or game patches would be present on your system; however other newer games you may have played, you might have noticed a you will need to update your system before you can play this game message on your screen. There are only 3 steps I can suggest the first is to reformat your system this will erase/revert everything to its default settings as if you're playing the console again for the first time. The 2nd would be to clear the concole cache and erase all updates. You do this method by going into system/memory/press y button/then press xx, left bumper, right bumper, xx if you do this correctly it will ask if you want to perform maintenance select yes. The 3rd option I have will erase any faulty updates which may have not completed etc. that may be causing an error, you do this by holding the synchronize button (just to left of power) then turn the power on, continue to hold the sync button until it loads completely then release. You will not receive any message or indication but any failed updates will now be removed from your system. Hope this helps, I would try these steps from 3 to 1 if I were you to, so hopefully you don't have to wipe all your saved games
SOURCE: I had all of my games installed on my xbox 360
There is no way to retrieve it. By deleting the games and their memory from the system, you've erased all of your progress with them.
