SOURCE: carburetor adjustment weed eater fl sst 25,will
My machine didn't run idle either. Took carburator apart of the Sst 25. Cleaned it with gasoline and a brush. But no luck. Figured it must be the nozzle of the idle. There are two more or less hidden black adjustment screws for the nozzles (idle and gas). I used a plastic tube from a ballpoint to take screw out, ran some air through it, reassembled it and now the machine runs smooth again...
SOURCE: Can not start my stihl Fs66 weedeater
Turn both screws CW to stops (lightly), then back out CCW 1-3/4 turns each. This a basic setting and both will need to be set leaner (CW) after the engine warms up. Remove the spark plug and check for blue sparks when the engine is pulled through. If nothing, try a new spark plug. If still nothing, try removing the stop switch connection at the ignition module and retry for sparks. If nothing again, replace the ignition module. Use a thin business card to set the pole gap (the magnets should be under the poles of the ignition module) when installing the replacement. If you get sparks in the first test, try spraying some carburetor cleaner in the plug hole, replace the plug, and attempt to start. If you get a pop or two, then you have fuel problems. Check the fuel lines for condition, check the filter inside the fuel tank for plugging, and tightness of the carburetor screws and nuts. Remove the muffler and check for plugging. Check the air cleaner for plugging. If it still won't run, then the carburetor should be removed, disassembled, cleaned, and fresh gaskets and diaphragms installed. Keep track of what went where as you remove parts. If the machine appears to have good compression, it should start. When the engine is warmed up, adjust the H needle to 4-stroke at high speed, but smooth out when cutting. The L needle should be adjusted to allow the engine to run fairly smoothly, but allow the engine to 'follow the throttle'. Idle speed should be set so that the string head does not turn, but keeps the engine running. Hope some of this will get you trimming again!
SOURCE: my stihl weed eater will start but not rev up
little cable with toggle on the end of it, this has come off the carb
SOURCE: Husqavarna 125L E TEC weed eater won't stay running
CHECK THE SCREEN ON OUTPUT OF THE MUFFLER. ITS CALLED A SPARK ARRESTOR, THESE GET OIL FOULED AND MAKE EM A BEAR TO RUN . CLEAN IT UP AND SHE WILL RUN LIKE A CHAMP, THE CARB MIGHT NEED REBUILDING ,FUEL FILTER AND A SPARK PLUG IS THE FIRST THING TO REPLACE .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
SOURCE: Poulan Weed Eater GHT220
there are mntwo different size fuel lines which one does the gas filter hook up to?
