Sharp DVMX1U DVD Player Logo
Posted on Jul 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Now have verizon Fios and cannot get DVD player to play
Ginko
Level 3:
  • Sharp Master 19,396 Answers
  • Posted on Jul 25, 2009
Ginko
Sharp Master
Level 3:
Answers
19396
Questions
25
Helped
8077725
Points
55462
Check the connection cable. If the Verizon box and the DVD player are connecting to the same TV input, ensure that the Verizon fios box is connecting to DVD input, and DVD output is connecting to TV.
If you connect DVD out to Verizon box input, and then TV , you will have to turn off the receiver box to see DVD.
If you use only one TV Input connect Verizon output to DVD input and DVD out to TV.
If instead you use separate inputs on TV, then try using the source/select input button on TV remote, and try different cables.
Regards.
2 Related Answers
Anonymous
  • 6 Answers
  • Posted on Apr 28, 2009
SOURCE: Will this DVD recorder work with Verizon FiOS?
6200_stereo_tv_vcr_dvd.jpgThis is the setup for the 6416 and the vcr.
Anonymous
  • 3 Answers
  • Posted on Dec 11, 2010
SOURCE: I have a Samsung BD-P1590 Blu-ray player and I am
1099 works for one for all remotes
Sony bravia volume control not working with FIOS STB
found the problem after reading a post on this site. Last thing I used was DVD player so disconnected DVD Sony player, followed the factory reset instructions and now the volume works normally! It was the DVD player. Thank you so much for the info and lead. The problem is DVD not TV,
Jul 20, 2014
HDTV goes blank when connected to Fios HD-DVR or Fios DTV recvr.
If you can first connect the Fios box via component and that will rectify the issue and still allow HD. HDMI is funny, if there is anykind of communication issues between the TV or the Fios box you see what happens. You might also call Samsung to see if there is ANY firmware/software updated for your TV specifically to fix such an issue with the Fios/Mortorola connection. If there isn't then the issue is the cable box since the TV works ok on HDMI with other devices.
I own a Go-Video DVD-VCR Player, Model DV3140. I recently switched to Verizon service and find that I can no longer olay my DVDs/VCRs with the Fios System. Can you assist me in how to program my player...
Hi
You can reprogram it by following these instructions--
Power turns on or off both your STB and TV when you are in STB mode. (If you have a DVR STB, the DVR will continue to record scheduled programs when off.) However, you can reprogram how the Power Key works. If you want the Power Key to control multiple devices at once --
1. Press and hold the STB key.
2. While holding down the STB key, press OK.
3. Release both keys. The Device Keys will blink twice.
4. Press 9 - 7 - 7. The STB key will blink twice.
5. One after the other, press each Device Key you want the Power Key to control, in the order you want them to turn on or off. Each selected device Key will blink twice after it is pressed.
6. Press OK when done. The STB key will blink three times to indicate success in programming.
For example, to program the Power Key to turn on or off your TV, AUX and
STB, in that order with one press of the Power Key, press [STB+OK], [9-7-7],
[TV], [AUX], [STB], [OK].
These are the codes for GO Video DVD Player--
Go Video 0771, 0768, 0810, 0896, 1071, 1102, 1185, 1757
You can view/download the manual for the fios from this link--
Verizon fios remote programming
You can visit this link for more information--
Verizon FiOS Troubleshooting
If you want to doanload the user manual for your verizon set top box you can get it from here
Please do accept this solution and revert for further assistance.
Thanks
Rylee
2helpful
4answers
NEED REMOTE CODE
Go on the Verizon website and request a new remote, the Verizon P265 Remote model. It will have all the newest firmware and it should have the code. I know this because I had a TCL 32" TV and the code wasn't on my old Philips RC 1445302 model. TV and new remote are "talking" just fine now. Verizon won't even want the old one back.
Can't record
id get some spliters and hook it up that way or call 888-553-1555 and up grade to a dvr where you can pause record and rewind live tv. or get the home media dvr where you can record 2 shows at one while watching a 3rd and record on the hmdvr and play that same show on up to 3 other tv's
2answers
How to connect to a fios digital box and sony trinitron
please provide more deatial. i am a verizon fios tech and im willing to help you.
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
