Garden Logo
Dave Wagner Posted on May 22, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you remove the cutting head , autocut c5 2 from the stihl weed trimmer
Stephen Miller
Level 3:
  • Master 1,645 Answers
  • Posted on Dec 30, 2018
Stephen Miller
Master
Level 3:
Answers
1645
Questions
0
Helped
864963
Points
9471
Go to youtube for more info
5 Related Answers
Anonymous
  • 16 Answers
  • Posted on Aug 31, 2009
SOURCE: Fix Coil Start Stihl Weed Trimmer
you dont say what model Stihl, lets assume its FS80/85. the torxs style screw driver is part of the tool kit supplied with the machine and includes spark plug spanner 3/4 AF, remove the four screws to release the starter assembly, the starter also retains the fuel tank, dont lose the oblong rubber insert or the tank will wobble around when assembled. if the rope wont return the end of the rewind spring may have broken off or it maybe that the spring has got so rusty its just hanging up. with the recoil off remove the centre screw (normal anti-clockwise) holding the starter away from your eyes, withdraw the pulley and inspect the spring for damage which normaly occurs at the end that engages with the pulley, if it's broken and you cant get a replacement use a pair of pliers to grip the spring about 3/4 inch from broken end, heat with blowtorch to soften and rebend into a hook to engage with the pulley, dont try to bend without softening, clean off any rust with wire wool and re-install the spring in it's housing working from the outside toward the middle.it's more of a knack than anything else and you could probably do with eleven fingers. having installed the spring make sure the rope is fully un-wound and insert the pulley into the housing turning gently until you feel the spring engage, you will know you've got it right when the pulley attempts to rewind, fit the pulley retaining screw, you will observe a notch in the outer rim of the pulley,make sure that the rope is in the notch and use it (the rope) to wind the spring about five times, check that the whole rope rewinds into the pulley, if you still have some hanging out put more turns on the spring but dont over do it. to check, gently pull on the grip until you come to the end of the rope, thats the important bit, you must come to the end of the rope before you come to the end of the spring otherwise the spring will break again.install the starter assembly by offering up and slowly pulling on the grip until you feel the pulley engage with the starter pawl. good luck.
Anonymous
  • 5 Answers
  • Posted on Sep 17, 2009
SOURCE: how to replace coil on stihl fs85 weed trimmer
Remove the starter & cylinder cover and look for the coil mounted next to the flywheel. Remove the 2 screws holding it to the cylinder and cafefully pull the wires through the clips that hold them to the block. Install the new coil in the reverse order and set the air gap between the flywheel and the coil with a business card. Let the magnets on the flywheel pull the coil towards it with the business card in between. Tighten the screws and spin the flywheel to remove the card. Reassemble the stater and blower housing.
nova2nv
Bill Linda Rivard
  • 197 Answers
  • Posted on Nov 28, 2009
SOURCE: Ref: Stihl FS46 string trimmer. Broken Flex shaft.
Remove orange sheild,remove single screw holding head in shaft then grab head with pliers and twist side to side until complete head is free.You should then be able to grab part of shaft.On power head loosen screws {about one turn each} that hold two white case halves near trigger,I think there are four,then there is a single torx screw on the bottom of lower case half in the middle that must be taken out to allow tube to be removed.Romove flexshaft from top.Check 4 plastic burnt to flexshaft,if there is you must replace tube liner as well,usally around bent part of tube the liner will go bad.
Anonymous
  • 41 Answers
  • Posted on Apr 14, 2010
SOURCE: Craftsman weed wacker trimmer head won't turn
it could still have the broken peice from the old one inside the seat.take it apart and look inside and inspect the seat where the drive cable enters.
Anonymous
  • 8197 Answers
  • Posted on Oct 27, 2010
SOURCE: Manual for a STIHL FS48
You can get the manual on the link below
http://www.stihlusa.com/information/info_product2.html
http://www.stihlusa.com/stihl_ownersmanuals/FS_45_46_Manual.pdf
3answers
Hi, I have a Stihl FS88 trimmer with an auto cut 'bump' head. What diameter line should I use please.
Dave, I use the orange 2.4 mm .095" line, seems to give the best results. Check the attached links,manual,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.stihlusa.com/WebContent/CMSFileLibrary/InstructionManuals/STIHL-FS-88-108-Owners-Instruction-Manual.pdf
How to Rewind Your Trimmer Head or Sharpen Metal Blades
HOW TO Stihl String Trimmer Head Replacement
Stihl trimmer autocut C-25 will not bump
have you wrapped the cable the right way? it only feeds out when the head is spinning
Stihl trimmer housing does not spring back
can you send pictures of the internal components?
How to line the feed on Stihl FR 106 Weed Eater Max 420 head
could you add a picture of the particular head you're using.
Autocut haed is clogged up with cutting twine
To remove the head put a small screw driver in the hole in the shaft down by the cutter head to lock it thenunscrew the whole head (it might be left hand thread) that should take your head off and you can remove the twine easily.
STIHL WEED TRIMMER
With the plug removed the starter should pull very easily. When trying start did the cutter head try to spin? If yes clutch springs may need replacement
Jul 24, 2013 • Garden
Stihl strimmer engine runs but wont cut grass the head wont turn what cuts grass
First take the head off and look for grass, weeds and string wound up in there. A lot of times that's the problem.
Next, with the head off and the switch in the off position, pull it over a few times and see if the shaft spins. If not, could be a broken shaft or a bad clutch.
Stihl fs 45 trouble getting the cutting head to engage
repair shop shortened shaft just a touch to take up slack in drive cable
Aug 02, 2009 • Garden
Top Stihl Garden Experts
Thomas Perkins
Thomas Perkins
Kardoc
ADMIN Andrew
ADMIN Andrew
Are you a Stihl Garden Expert? Answer questions, earn points and help others
