SOURCE: Temperature Setting Dial in Fridge
Hi. thanks for the question. # 9 is the high, 1 is low. and it will run for 24 hrs to get on track .thanks the appliance doc
SOURCE: Kelvinator Fridge/Freezer C 340 RM does not switch off
the problem is your thermostat in your frig.the dial with numbers on it.it is no longer sensing properly and theres nothing you can do but replace.that is as long as your dial is not broken[the plastic pice with the numbers] God bless ,tom
SOURCE: Refrigerator LG Model GR-T452G freezer works but
Locate your defrost timer, they are either in the buttom front of the refrigerator, in back of the refrigerator, or inside compartment behind the plastic covers. On the defrost timer there is a slot were it can be turned using a screwdriver, or there is a round window were you can see it running.when you turn this dial and it clicks, you should now go into defrost. with all the ice build up in your evaporator you should hear the ice cracking indicating that the heaters are working, if not you might have open defrost heaters.
SOURCE: Westinghouse 410l fridge trips new RCD's in fusebox
Tripping an earth leakage would indicate a break down of insulation in the windings of the compressor, the possibility of a short circuit in the wiring system or the defrost element down to earth. I recommend you have a certified technician check it out before you have a fire. If the Hoover is in good condition there is no reason not to replace it. Rate me please.
