Actually, $10 for a manual is probably a valuable investment. It will not only help you with threading & winding the bobbin but also with maintenance and care of your machine and as well as how to use your machine. Similar brand machines thread and wind the bobbin in the same manner. So, even finding a similar Necchi and the bobbin winding method should be helpful.
Or stop by the local fabric store (or even Amazon online) and pick up a standalone bobbin winder for about $25 US. You can wind all your bobbins on the little unit and not subject your machine to additional wear and tear.
it sounds like the thred tenshion is to loos or the timing has sliped a little and its off a bit this can also happen with wear on the gears or just a loos fixing letting the timing slip back a bit,
Try moving the stitch length dial to 4 or 5 - check the manual. You may have it in the position for very close together sewing. I had to do a lot of trying with my 4795 to get it to work right. I found that very thin thread, polyester kind, broke at the needle after a couple of stitches. I switched to coats & clarks thread and a Singer ball point needle and it works fine. Be sure your needle is inserted with the flat top toward the back of the machine. Good luck!
