I have a couple of Copies Canon imageCLASS D320 Printer Copiers. I have changed out the S-35 cartridge and there is some improvement, but no matter what the settings the copies are extremely light to light at best. Is there a maintenance procedure I might do to bring back the print quality? I use fresh OEM S-35s.
Is there a way to find what the total machine count is? and if so how do u do it?
Hi im jules_09,check the developer,if its past over 60,000 copies if its over 60,000 copies you need to change the developer along with the opc drum and cleaning blade or roller,all copiers need to be replaced with new developer,opc drum and cleanign blade or roller when it reach its copy life,that may be the cause of light copy of print
What is the part number for the Canon imageCLASS D320 developer that I would need to order. I assume "jules_09" is saying the the Canon S-35 cartridge does not containg this part and it is a seperate order and install item. Also, is there a link to a how to change out the developer for the Canon imageCLASS D320 as I thought it was part of the S-35 assembly and don't have a clue as to it's location or how to change out?
MY LIGHTLY USED CANON D320 WILL ONLY PRINT LIGHT COPIES. REPLACING THE INK CARTRIGE DID NOT HELP. WHAT TO DO?
JACK
[email protected]
I HAVE PRINT ON ONE SIDE OF THE SHEET AND WHITE ON THE OTHER SIDE, CHANGING CARTRIDGES DOES NOT HELP, ANY IDEAS?
light copy i had changed the cd unit,hvt,transver,cd drive belt&gear,lazer unit . but no improvement
