SOURCE: will only shoot one brad and then stops
its problem is too much oil or not enough. never the less, it needs taken apart and cleaned and inspected. make sure you are shooting the right guage and brand hardware. generic doesnt always work.
SOURCE: staple gun model 0-tre550 keeps stopping when
My electric stapler has quit working. Why would it do that.
SOURCE: How do you load nails into a stanley tre550 nail
there should be a button on the bottom rear of the gun, when you press it, it should release a bar that you pull back. the nails go in the dirction you nail them. sometimes the clips are too big for the guns and you have to break about an inch off of them
SOURCE: Need help loading staples in my Stanley electric staple/nail gun
there should be a button / lever at the rear press it and it should open so as to insert the staples
SOURCE: stanley bostitch double fires. It is an older
You did not list your model number, however most bostitch nailers use the tva6 trigger valve. As this valve wears it will be erratic. Examine the firing pin that makes contact with trigger. If it looks worn or wabbles from side to side, then time to replace. To remove valve first remove trigger by removing roll with 3MM punch. Next remove one or two roll pins just above the valve, also 3mm. With roll pins removed air pressure will pop out valve. Be carefull because valve can come out with force, use glove or rag to catch. Parts available at www.toolpartsdirect.com, or generic valve at www.ebay.com. Good luck
