Televison & Video Logo
A
Anonymous Posted on May 07, 2017
A C Remote indicate HP and C 1 and LP - HP Televison & Video
2answers
How do u know weather to put it on HP or LP an where to set them at
Keep 1 post per subject open please! It is confusing to follow! The HP is High pass and LP is Low pass, HP is for tweeters and LP is for Sub woofers!
6helpful
2answers
LP HP CF Blue star
11TR Blue star Ductebal AC LP HP CF porbalem
I have a Rheem rtg 74dvp but its not heating and the display show me 1 76 and 2 76, and come all the time to 76 F and another times its blinking the temperature, but not heat
Error code 76 is communication problem between remote control and tankless unit.
http://waterheatertimer.org/pdf/Rheem-error-code-C7-76.pdf
Multiple error codes could indicate that main PC board is bad.
Before calling service technician, open following link for troubleshooting resources including link to Rheem chat, manuals, error codes, etc.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
10helpful
2answers
LP,HP AND CF APPEARS ON HANDSET AFTER RUNNING THE UNIT IN BLUE STAR DUCTABLE UNIT. PLS SOLVE IT
after starting of ac units it shows lp hp but once reset than the lp hp thing goes away what is the reason for showing lp, hp in the morning when started first time in the morning
Tried out new weber performer grill, gas assist lights up right away, but goes out in about 2 - 3 minutes, tried restart no go, 16 oz bottle empty, tried my back up same result. Online research indicated...
Temperature does have a substantial effect on LP.
Propane will not flow properly when it is too cold.
You might warm up the canister to room temperature before grilling, but I'm not sure if that will let you finish grilling first.
For my mode should it be hp or lp
hp they provide lp, lp is tust an lp.... so your mode should be lp
Do you have instructions for wiring install on volfenhag GX8200??
Amplifier Class AB
Number of Channels 2
RMS Power (4 ohms) 120 watts x 2 channels
RMS Power (2 ohms) 200 watts x 2 channels
RMS Power (1 ohm) Not Stable
Bridged RMS Power 400 watts x 1 channel
Total RMS Power Output 400 watts
Peak Power Output 1000 watts watts x 1 channel
Minimum Impedance Unbridged 2 ohms
Minimum Impedance Bridged 4 ohms
THD at Rated RMS Power 0.1%
Speaker Level Inputs No
Preamp Outputs 1 pair
Built-in Crossover High-pass (HP), Low-pass (LP), Full (AP)
High-Pass Crossover Frequency 40 - 250 Hz
Low-Pass Crossover Frequency 40 - 250 Hz
Subsonic Filter N/A
Signal-to-Noise Ratio N/A
Channel Separation N/A
Bass Boost 0 - 18 dB
Bass/Gain Remote Yes
Fan Cooled Yes
Fuse Rating 20A x 2
Top HP Televison & Video Experts
 Mikey
Mikey
Stan Ford
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
