Computers & Internet Logo
T
Tammy Hardie Posted on May 07, 2017
After a power outage my Asus Aspire E380 will not turn on. Everything seems to be working but no signal on my monitor and black screen.can you help?
5 Related Answers
Anonymous
  • 116 Answers
  • Posted on Nov 26, 2007
SOURCE: monitor goes black
Sorry to have to tell you this, but this is common in LCD monitors. The reason that it is going black when it boots is for one of two reasons. You either have a bad power supply that powers your LCD or your LCD's backlight is blown. These can be repaired or you can purchase a new one. But if it goes black 9 times out of 10 is because the backlight is bad. These can be repaired!
Anonymous
  • Posted on Feb 12, 2008
SOURCE: Acer Aspire 5570z
i need audio driver and display driver of acer aspire 5570Z
Anonymous
  • 198 Answers
  • Posted on Feb 20, 2008
SOURCE: No picture on the screen
I have this Panasonic PanaSync SL70 17'' monitor, I don't use it often. It is still in very great shape. However, I tried to turn it on yesterday, I got a black screen. The power LED is on and I can hear the relay is clicking when signal received. I tried to remove the signal cable, I can see it turns to power saving mode. It seems that everything works fine except no picture. I am if the transformer is gone, but not sure. I am wondering if you can help?
Anonymous
  • 152 Answers
  • Posted on Apr 03, 2009
SOURCE: gateway monitor, black screen with blinking power button
wjfarm48, Sure sounds like a power supply problem. How old is it? How many hours of use? Do you understand what a switch-mode-power-supply and an inverter supply is? If not, then here are your options. Check with Gateway to see if there is a swapout program. You box up and ship them your monitor+cash, and they return a REFURBISHED same model with new CCF tubes and inverter/SMPS. When you box up the monitor, follow this lead. "A 3 inch thick layer of breathable air shall be the only thing touching the lcd front panel" Next option is find some local TV/Monitor repair guy who can get parts and or replacement boards/CCFtubes from Gateway. Last but not least, is to repair yourself. Not Recomended.. But do a search on lcd monitor repair or Bad Capacitors In LCD Monitors or Repair of SMPS in LCD/FPD Monitors. Also check for videos on YouTUBE related to lcd monitor repair just for your own info. Here 's what you are dealing with. The light that makes your FPD bright white is generated by Cold Cathode Fluorescent Tubes (2) that require 600-1200vac at high frequency that is generated by an INVERTER which gets 12-24vdc from the SMPS. Almost the same technology is used in the new style screw-in curlie-que Compact Fluorescent light bulbs. Only they call the inverter a electronic ballast. Anyway, thats about all the info I have. Let me know how you make out in you quest to get your LCD up and running again. I'm louie12fix on fixya or lmistyrel@ aol.com BYE for now.
Anonymous
  • 1015 Answers
  • Posted on Sep 08, 2009
SOURCE: Monitor Blacks Out Randomly
Well If the monitor is brand new and you just purchased I would take it back and get another one as it appears to be defective. Most stores will allow you to exchange a defective item without a problem as long as you have the receipt. Any attemot to make repairs yourself could void the warranty. If it is used it may still be under warranty...I would get the model/serial number and contact Asus to have repairs made. Most monitors have at least a one year warranty.
1helpful
Screen remains black when coming out of sleep mode asus a8n-vm cms motherboard
IT is most probably windows 7 issue. I saw problem with desktop computers coming back from sleep for many times.
I advice you to avoid sleep. If that is not issue, first test memory, cause sleep stores everything to the memory.
Please tell which OS you use ? As said on start it might be Windows 7 ...
Why does my asus monitor always read "no signal".
nah that happens with me sometimes..
have you connect the cable properly?
if that still can't make it works, first turn on your PC and monitor..
then plug off the cable that power them, so that your computer and monitor will suddenly off..
plug it on again, then your monitor will work again..
that works on mine cause my CPU is too old and had a power problem..
Shut down my computer aspire e380 then disconnected the monitor from the computer and power to move it. reconnected the monitor turned the computer back on and monitor says no signal.
make sure all the plugs are plugged in snuggly turn off the computer again then turn on the screen. next power on the computer. if that does not solve the problem you may have an issue with the video card.
1helpful
Acer aspire ase380 power switch problem
do you get the self test screen on the monitor. is so it is not communicating with comp. bad video port most likely
Acer E380 monitor issues
the display signal is not coming from your pc check the RAM of your pc
Computer will not load.
use safe mode..do a disc clean, defrag..and then reboot...sounds like the operating system headers went unhappy when you moved it(which I highly recommend you NOT do again)..
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
