Kitchen Ranges Logo
Audra DeMarco Posted on May 05, 2017
Was using the broiler on the magic chef gas stove and it stopped working and started flashing codes on display what does L1 and L3 mean on the gas stove when flashing
5 Related Answers
brian smith
  • 27 Answers
  • Posted on Nov 01, 2007
SOURCE: Magic Chef 6551WUW Oven
is the element still in one piece and mostly smooth to the touch? if you find any part of the element very rough where it looks like it actually melted then you've found your problem. post an update if this doesn't solve the problem.
Anonymous
  • Posted on May 14, 2008
SOURCE: "F1" error code on Magic Chef gas range Model 3488XRA
the burners on my magic chef stove work but the flame is not as high as it should be on one burner. I switched the top of the burner with another and it did not solve the problem.
Anonymous
  • 217 Answers
  • Posted on Nov 30, 2008
SOURCE: f3, f1 error mesage on magic chef stove, oven not working
http://www.applianceblog.com/mainforums/showthread.php?t=7643 click this link
Anonymous
  • 530 Answers
  • Posted on May 28, 2009
SOURCE: Magic Chef oven & broiler do not work
you know i am thinking more towards a bad temp probe.
woodchuck789
Charles T Nevin
  • 4070 Answers
  • Posted on Mar 11, 2010
SOURCE: Error Code F7
F7 Function key shorted Replace touch padThis is what the code means. The key could just be stuck. Try pushing it several times to see if it will unstick. before you replace the touchpad.
F-1 displays of magic chef gas stove and buzzer sounds
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced GENE
Magic Chef Broiler won't turn off
If this is brand new you need to get this taken care of under warranty. Any thing you try to do to repair will void the warranty and with all the electronics on this stove you want warranty to repair. Sorry I wasn't much help but you don't want the warranty voided.
Magic Chef gas stove periodically starts beeping and "F-1" appears in the display
Hi alflaw,
F1 error indicates a bad touch pad or clock (ERC). To fix this error code, replace touch pad or clock (ERC). Touch pad is a more common problem.
Hope it helps.
Thank you for using FixYa.
1helpful
Magic chef gas stove
i searched and never got one . so my solution is not to use the stove and be creative how i make suppers. so that is how i fixed it. do without and go on.
F0 fault code on magic chef gas range
Do not recognize a F0 code only F1-F10. Recommend unplugging and replug.
2helpful
Replacement Parts For Vintage Magic Chef stove
You probably have a 1940's model of Magic Chef. Check for the model number under the lid of the cook top on the upper right hand side of the stove. It should have the model number and the serial number, too. You will need both. The Old Applicance Club run by Jack Santoro is the place to go along with a site called "Antique gas stoves"in Georgia. Good luck with the world of vintage stoves.
I'm not sure how to fix this, but my mom's magic chef has been doing this for close to 10 years. She's managed it by plugging a power strip into the wall outlet and plugging the stove into the power strip. Then she can just turn on the strip when she needs to use the oven. It only requires moving the unit once, and is easy for the technological/ home repair novice.
Top Magic Chef Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
