SOURCE: Add links to a Lucien Piccard 26006SS
You may have
arrows inside bracelet.Arrows are pointing the way the pins must come
out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws.
If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx.
size of pin end diameter using any sharpening stone or sandpaper. Get
an old towel and fold it to make a soft base for work (like small
cusion). As you don't have a special bracelet holder you will need a
pair of helping hands to hold the bracelet steady upright. You will
need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make
sure that the grooved pin ends are facing towel, not the needle and
hammer!!!
Now place the watch on the folded towel, take that needle and smallest
hammer you have and start driving the pin out using light blows. Do Not
hit hard, as you will brake the needle, scratch your watch or even
injure yourself. Watchmakers are using 45 gram hammer, so, calculate
your strength of blows.
After a few blows check if the split end is coming out and when you see
that the end is long enough to grab it with pliers, pull the pin out
with pliers. When pulling, do NOT turn pliers, as pins tend to brake
when twisted. Use firm grip and your strength to pull the pin without
twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY
the same way as they came out- the blunt end first in the hole and the
split (grooved) end last. Before doing that check remaining pins in
bracelet to make sure that you put them back from the right side of
bracelet.
It is recommended to use plastic hammer to drive pins back in or you
will scratch or damage bracelet. If plastic hammer is not available use
an old toothbrush handle (or some plastic item) as an absorber. Simply
put pin into the hole as deep as you can with your fingers, put the
toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
SOURCE: I have an antique bulova
Hi!
You can't tell actually the date when it is manufactured by the serial number of the case metal.
However if you manage to open the backside and look in the inside there will be markings that will help in the dating of the watch.. Look at the image below for example
as soon as you open the back case there is a symbol (pointing by red arrow) that was being used that time for dating.
From the table below.
Dating at the early 50's are different. 2 digits printed on the backcase signifies the date manufactured.
L indicates 50's
M indicates 60's
N indicates 70's
so if you see a 2 digit stamped on the backcase for example is L2
then it means it is made on 1952.
You will not find this information unless there is a 2 digit on the backcase or you will find a geometric symbol inside the case of your watches.
I hope this helps
Please accept if you find this solution helpful
Thank you for using Fixya.
Alp
SOURCE: Anyone know how to date
Hi tmacar,
Kindly refer to this link for the instruction on how you can set date for your Lucien Piccard Circa 101 automatic watch.
Hope it helps.
SOURCE: whats the value serial number 980512 lucien piccard
Probably not what you paid for it, sad to say. So many were made, and with the recession and the advent of a reliable timepiece in everyone's pocket anyway, the collector's market for elegant wristwatches has declined somewhat. It also varies dramatically depending on what kind of market you're selling in. Pawnbrokers, jewelers, and watch collectors all have different ideas of how to determine a piece's value. Condition and provenance also play a large part of any appraisal. I wouldn't accept less than $250 if I were you, but I wouldn't expect more than $500. In the long run, your best bet to have it keep its' value would be to keep it until it can be classified as vintage or an antique. Once most of the other Lucien Piccard watches that were made at the same time as it was have failed, been melted for gold or lost, the value will start to go up again, and if you or your family can keep it for a VERY long time indeed, then it's definitely possible to make a profit on a watch.
fixya is not a jewelry appraiser take to a jeweler for appraisal
