Question about Microwave Ovens
Kitchen aid microwave oven door sags - Microwave Ovens
    Master:
  • 257 Answers
It could be the torsion springs...
check the link Replacing Microwave Torsion Springs Technician Brian
Posted on Apr 24, 2017
6ya staff
SOURCE:
Mod.KHMS155LSS-1 Getting F-6 Fault code ????
Search Results
    Combination Microwave Wall Oven - Error Code/Message ...
    www.kitchenaid.com/...microwave...error-code...f6-error-cod...
    KitchenAidQuestion: Combination Microwave Wall Oven - Error Code/Message - F6 Error Code -F6 E8. Answer. Product Symptom: Combination Microwave Wall Oven ...
    Over-the-Range Microwave - Error Code - Starts with F ...
    www.kitchenaid.com/...microwave-error-code...f...f6...code/P...
    KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
    Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
Feb 05, 2016 | KitchenAid Microwave Ovens
Frigidaire microwave door is sagging
Hello Irfan, thank you for your post!
From the information you have provided the door on your Frigidaire microwave is sagging. Your door could be sagging due to the hinges or the door being damaged. I would check to make sure there is no visible damage. It is possible that the hinges and door may need to be replaced as well. To help avoid any unnecessary part purchases you may need to seek assistance from a professional technician for proper repairs. -Matt
Aug 10, 2015 | Frigidaire Microwave Ovens
Why won't my interior microwave light turn off and my microwave won't start?
It sounds to me that your door switches aren't working.Your oven is protected by a couple of switches that engage when you open or close the door.They control a couple of safety features and also your interior light.One of them seems defective.
Dec 17, 2014 | KitchenAid Microwave Ovens
I have a kitchen aid microwave and have had it repaired at a autherized sevice center and it had a blown fuse. Now I have another fuse that has blown. It does it when the door opens and then blows leaving...
When the fuse blows in the microwave oven, it is often caused by a bad door switch. Sometimes food build up will clog it, or becomes defective, the only way to fix it is have it replaced.
Mar 30, 2011 | KitchenAid KCMS145J Microwave Oven
Hi!! My Kitchen Aid superba microwave oven says door and the door seems to work okay. Any suggestions?
the micro switch is probably faulty which tells the machine the door is actually closed or open. this would need replacing which means pulling the unit apart.
hope this helps
Aug 20, 2010 | KitchenAid Microwave Ovens
Burned out bulb on Kitchen Aid Microwave Model KBMC140
You will need to remove the oven from the wall and remove the outer cover.
If for some reason you don't have yours, you can download your owner's manual and installation instructions free from this page.
You can also find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
These models use halogen lamps. You must not touch halogen types with your bare skin, as the oils will shorten the bulb life.
You should be able to get one from a home center or local appliance parts store.
If you order it online (from the link above) it is part # 4375348.
Aug 04, 2009 | KitchenAid KBMC140HSS Convection/Microwave...
Sagging microwave door
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
If the door seal is damaged or out of alignment, there is a chance of leakage, which can cause burns, damage to the oven or even a fire hazard.
Feb 08, 2009 | Frigidaire FMV156DC Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
