Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
SOURCE: plasma tv has no picture but green led is on
Try unplugging the TV for a few minutes (discharges the ballast/ps) then plug in and attempt to power on. I have the 42P Vizio over two years old and ran into the same problem a few times. First thought was a power supply issue, but the unplugging trick worked. Good luck.
SOURCE: Samsung 40" LED TV Display
Not familiar with this particular model of samsung LED TV, but ghosting and shadowing are usually an accepted manufacturer's defect.
If you're still under warranty or within 30 days of purchase, contact the company that sold you the TV or Samsung warranty department.
If you're out of warranty and you don't wish to deal with this, contact a TV repair shop. They will most likely tell you that it's not worth repairing and recommend you purchase a new TV.
SOURCE: trouble locating correct location for tv on/off sensor
i have phoned bose the tv sensor will not work with led tvs becouse they do not transmitt enough power for the sensor to pick it up
SOURCE: Samsung PS42B430 42" Plasma tv. LED flashes and
The tv power supply board have more dead components parts,u just don't have the skills an the know how to trouble shoot find out more dead components parts that all.Try website like Ebay.com to buy a whole refurbish power supply board for the replacement.
