Question about KitchenAid Microwave Ovens
What is the item number for a Kitchenaid Microwave "inlet cover" for microwave model KCMS2255BSS
6ya staff
SOURCE:
tiway1
Tim martin
  • 100 Answers
SOURCE: Turntable motor - Sanyo Microwave Model EM-S8000W
There are actually two, both Panasonic motors...
Here are the full links...
http://microwaveglasstrays.com/shop/120v-microwave-turntable-motor-253w-b6326408ap-p-215.html
http://microwaveglasstrays.com/shop/120v-microwave-turntable-motor-6rpm-f63265g60ap-p-217.html
Here's the link to their main page for motors...
www.martinmicrowave.com
Posted on Sep 06, 2008
THENTHEREWER
Terry Rodgers Jr.
  • 131 Answers
SOURCE: How do I replace a lightbulb in my Kitchenaid microwave?
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=KEMS307DBS&siteCd=KAD#parts_list HEY ANDYCOOL,GO TO THIS LINK IT'LL SHOW YOU ANYTHING YOUR HEART DESIRES ABOUT THIS UNIT(DRAWINGS,USER MANUAL,PARTS LIST,INSTALLATION GUIDE,ECT.)SORRY BUT FROM THE LOOKS OF IT YOUR GONNA HAVE TO PULL THAT PUPPY.BUT YOU BE THE JUDGE OF THAT.GOOD LUCK,HOPE THIS HELPS!!!!
Posted on Nov 08, 2008
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: Kitchenaid KHMS155LSS 1000 watt microwave makes grinding noise
Chances are you have a bad stirrer motor or the stirrer blade is jamming or loose on the motor shaft.
Your owner's manual should tell you how to remove the stirrer cover to check it.
If for some reason you don't have your owner's manual, you can download it free here, as well as the parts manual for your model.
You can also find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Jan 01, 2009
Anonymous
SOURCE: Microwave Oven Door Spring Replacement
Remove the front panel by removing the screws located on the inside of the door (note hold door inplace, since it is heavy and will fall out after screws removed). Unscrew screws located on bottom of plastic retainer (2 each) Remove tension spring. Note 2 are included right and left. Note color of spring on end, different springs for different door types, stainless, black,beige or white. Replace all in reverse order.
Posted on Mar 26, 2009
Anonymous
SOURCE: microwave model KHMS155LSS-3 turns self on
I had the same problem with the same model of KitchenAid Microwave. KitchenAid customer service will act like they never heard of the problem, although if you google it, you will find that this is a very common problem. Ask to be transferred to the safety department. After more than 6 months of complaining and several repair attempts (they replaced control panel and switches), KitchenAid finally gave me a full refund. This is a serious safety defect for which they have no fix. The product needs to be recalled, and I am willing to testify that KitchenAid was criminally negligent when this product finally causes a house fire and possibly serious injury or death.
Posted on Dec 04, 2009
Where can I find out the wattage of my Kitchenaid Superba 853879154001 Combination Microwave? It is not on the door sticker.
Sarah,
That model number is not coming up as a good number, but another model that I looked at said that particular model was a 900 watt microwave.
Aug 08, 2015 | KitchenAid Microwave Ovens
How do I change light bulb in Kitchenaid Microwave KCMS1555RSS
You will need to remove the cabinet to change the bulb, the part number is 4359741, now the bulb is part of the base so the part number is the correct part for this model. Good luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Mar 14, 2015 | KitchenAid KCMS1555SSS Microwave Oven
KitchenAid KCMC155J 1000 Watts Convection / Microwave Oven - how to change the light bulbs - can this be done without having to call a tech?
Look for a small cover on the outside of the cabinet in the place where the bulb is. They are usually secured with a single *****. It is the only part of a microwave oven that is consumer serviceable! Remove the cover and unscrew the bulb, replace and refix the cover.
your manual is here but doesn't mention the bulb
http://www.manualslib.com/manual/88077/Kitchenaid-Kcmc155j.html#manual
KitchenAid KCMC155J Use Care Manual
Mar 11, 2013 | KitchenAid KCMC155J Convection/Microwave...
Door open button won't work on KitchenAid microwave model YKCMS135H
Page 3 of the exploded view here shows the door open parts 24510L and 250201 (or 23551B if your full model number is YKCMS135HSS).
What look like part numbers seem to be reference numbers.
For further help you will need to contact Kitchenaid Canada here.
Sep 05, 2012 | KitchenAid KCMS1555RSS Stainless Steel...
CLICKING SOUND FROM MICROWAVE INLET COVER
not sure what you mean by inlet cover. However there is a fan in the unit and sometimes the fan will slip down and start clicking because it is touching the housing. check the fan and if that is not the problem then repost with what you have found. also brand and model numbers would help. the more info you give then the better we can solve your problem. thanks
Jun 22, 2011 | Microwave Ovens
Replacement of the Cover Inlet plate inside the microwave, this is part # 8184604. I have the part, I just need to know what to do to replace it. Thanks,
Hi
To locate the inlet cover, look towards the interior side of the microwave next to the microwave display. The inlet is typically located near the back of the microwave, in the middle of the wall.
Unplug your microwave from the electrical outlet and remove any food or containers.
Wipe the inlet cover, typically located on the right side of the microwave in the middle of the wall, with a damp cloth. The cover must be kept clean or it will not protect the microwave.
Dry the inlet cover with a soft towel.
Leave the microwave door open for several hours to air out the inlet cover.
Examine the inlet cover for wear and tear. If the cover has too much damage in the form of scratches or holes, it may need replacement.
Remove the inlet cover, if desired. Insert a putty knife under the plastic nail that holds the inlet cover in place. Pry out the nails and set them aside. Pull out the micro plate in front of the inlet and set it aside. Remove the inlet plate.
Install a new inlet plate. Slide the new inlet cover into its place. Replace the nails back into the side of the microwave by aligning them with the holes of the side.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Apr 20, 2011 | KitchenAid KHMS145KSS Microwave Oven
KitchenAid Model: KHHS179L Serial No: TR3314099 Experiencing heavy sparking. Where is Wave Guide cover, and how to replace it if necessary. Oven is mounted above stove and too heavy for this old man...
In your owner's manual (available free online here) this is called the "microwave inlet cover".
See the tag in your oven cooking cavity or near the door frame for your full model number.
The cover is located in the ceiling of the oven.
You should be able to remove and clean or replace the cover without removing the oven from the wall.
The oven installation instructions and parts list are also on that page.
You can also find handy exploded views and order any needed parts and accessories by model or part number here.
Jan 15, 2011 | KitchenAid KHHS179LSS Convection /...
I have a Kitchenaid combo unit of Oven & Microwave. Model YKEMC308KM01, Serial # XP4603281.Can someone help me as to how to change the light bulb of the microwave. I simply dont see any openings on the...
That's covered on page 21 of your owner's manual.
If for some reason you don't have yours, you can download it free here.
To Replace:
Before replacing, make sure the oven is off and cool.
1. Disconnect power.
2. Remove glass light cover by grasping the front edge and
pulling away from oven.
3. Remove bulb from socket.
4. Replace bulb, replace bulb cover by snapping back into wall.
5. Reconnect power.
You can find handy exploded views and order parts by model number here.
Dec 18, 2010 | KitchenAid KBMC140HSS Convection/Microwave...
Kitchenaid microwave (builtin) door jammed
I believe the only way of gaining access to the door latch assembly is by removing the cover. You can use needle nose pliers to grip the sides of the screws to slowly turn them out. You might want to visit this web site www.applianceaid.com enter your model number then scroll down until you see an exploded view of your model. Click to enlarge the diagram of your model exposing the latch assembly. I hope this is of help to you. If you found any of these suggestions helpful, please rate my solution. D. Lange
Apr 11, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Jan 01, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Microwave Ovens Logo
46 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Thomas F. Schneider
Jerry Greenberg
Jerry Greenberg
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
