Mitsubishi WS-55859 55" Rear Projection Television Logo
Posted on Jul 24, 2009
Tv does not stay on
TV was working fine. Shut it off with the button on the front panel of tv. Went to turn it back on...it goes on, green light comes on, then 3 seconds later, it shuts itself off. Will not stay on. Never had a problem until this. TV is about 8-9 years old.
neOen
Level 1:
  • Contributor 36 Answers
  • Posted on Jul 24, 2009
neOen
Contributor
Level 1:
Answers
36
Questions
0
Helped
17906
Points
69
If you have a rear projection, it is the bulb. Ypou need to replace it.
Tv will not stay on
Tv won't stay on - Fixya
www.fixya.com/support/t101679-tv_stay
Tv won't stay on My tv comes on, the power light comes on, but it won't stay on, it goes off by itself a few seconds - RCA F27450 27" TV question. ... My TV will notcome on, when I hit the power button the green light flashes but the ..... Please do Note: The front panel buttons must be used, NOT those on the Remote Control.
Why won't my TV stay on? ' Yahoo Answers
Sanyo dp50747
sounds like a mainboard problem
1helpful
Screen went black. Shut t.v. off and tried to turn it back on. Power comes on, front light is green, and in about 3 seconds the t.v. shuts off, green light goes off. Was playing dvd at the time. Shut off...
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device" and "menu"buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix. SD TECH
2helpful
While watching tv it just turned off, we turned it back on but no pictures but there is volume. also to turn it back on we see red light and green light together flashing then it turns off. i just replaced...
MY TV TURNS OFF AFTER WE TURN IT ON IT GOES BACK OFF A FEW TIMES AND THEN STAYS ON. AND WHEN I COME HOME FROM WORK IT STARTS ALL OVER AGAIN, THAT HAPPENED FOR 2 WKS NOW IT JUST GOES OFF YOU ONLY SEE THE GREEN LIGHT ON THE FRONT COME ON(POWER LIGHT) AND IT GOES RIGHT BACK OFF IT WILL NOT STAY ON
2answers
Need Help big screen turns on thens goes off
a tv has two components, firstly a power supply produces high voltage to trigger a line transformer, in turn a transformer produces smaller voltages. firstly check if the ht is constantly been produced from a supply, if this is there than go to a line transformer, and check voltages at the output.
2helpful
3answers
Tv wont turn on
TV STARTS UP AND GOES BLANK SOUND NO PICTURE
5answers
Philips 42 in. Plasma shut down
did u cheak the input cables does it do it on dvd input as well as others ?
2answers
Rca model# d52w135d screen won't turn on
Are you saying that the screen goes black after the DVD player stops working?
4answers
Won't power, light goes green 5-10 seconds later red flashing light is basically what's its doing. at 1st i'd power down the tv for a min and then it comes back up with no red flashing going on.
keep pressing the channel up/down button and the screen will come on it may take a few minutes dont use the switch on the side of tv just use the remote buttons u could try the power button on the remote aswell
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
