SOURCE: my gps will not recognise my sd card or turn on
Try the clear flash utility. It worked for me. Martin
SOURCE: sd card error on canon powershot s3
I get a memory card error everytime I insert a memory card. They are not locked and I have tried 4 different memory cards and nothing works. How can this problem be fixed?
SOURCE: my phone is not recongnizing that my SD card is inserted.
try reformatting the sd by getting a micro sd card converter and hooking it up to your comp.if this doesn't work then try a different sd card.if that one doesn't work then there is a problem with the phone.if you got any more qeustions email me at [email protected]
SOURCE: i am getting error message that sd card is blank
The problem could be your SD card. Try your SD card on a friends phone. If the same problem occurs, get your SD card repaired. Most SD card companies provide you with unlimited warranty so there should not be a problem.
SOURCE: Car: Toyota Rav4, 2004 Navi: AISIN
HI, sorry it's not a solution but i'm having the same issue, did you sort it?
