Question about Kenmore Microwave Ovens
Why Kenmore microwave oven (model 80089700) start/enter button not working while all other buttons works fine?
Kenmore microwave oven (model 80089700) start/enter button not working. I accidentally pressed something power button again and again and the start button stopped working. every other button works fine. when i reset the power, it asks me to set clock and when i was setting clock, i presses start button and it worked fine but for using microwave, it doesn't work. anyone know what is going on here?
    Sergeant:
  • 248 Answers
Safety system locking out the start switch. Door not closed, mode and timer not set etc.
Posted on Apr 10, 2017
  • dolly
    dolly Apr 11, 2017
    Door is closed but light inside microwave doesn't go off. Any idea on how to change safety system or reset the microwave oven so that it comes out of it? Thanks.
  • Gerard McHugh Apr 12, 2017
    You say the light inside doesn't go off? The door maybe closed but electrically the machine still thinks it's open (faulty door switch)
Anonymous
SOURCE:
Clock will not set time
Most microwaves just need to have the clock button pressed 1 time. Then you enter the time. Next some want to to pick am or pm. Then press clock again to set. Sometime last step is the start button instead of clock.
Mar 02, 2015 | Kenmore Elite White 1.5 Cu. Ft. Convection...
How do I fix the key pad of a Kenmore microwave model 401.80084700?
I don't know of anyway to repair the keypad. Usually replacement (of the keypad/control console) is the only option. But you might want to remove the ribbon cable that connects the keypad to the control board behind it, clean it with a degreaser (like Fantastic or 409), dry it, and re-insert it, and then try again. (Remember to unplug the microwave oven first before you try that!)
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Jul 07, 2014 | Kenmore Microwave Ovens
Power level change
You may have to enter a value with the number keys.
A 5 might give you 50% power or you might have to enter 50.
It all depends on the manufacturer's program. I'm not familiar with this model.
Feb 06, 2014 | Kenmore 62109 Microwave Oven
Kenmore over the range microwave oven model 721.80413500 keypad just stopped working. No response when pressing any button, even the light and fan button. Microwave was working fine minutes before.
80% of power problems are caused by ceramic fuse locted under microwave cabnet.Use a tester to see if you have continuity.You may just need a fuse.
Jan 29, 2011 | Kenmore Microwave Ovens
Icant figuire out how to set clock on a maison microwav oven sold by aldi stores
Here are instructions on setting the time on the maison microwave sold by Aldi:- 1. Press the "clock" button 2. Press the "Cancel" button 3. Enter the time (at least 3 digits need to be entered) 4. Press the "clock" button again Hope this helps
Sep 12, 2009 | Microwave Ovens
No Power
HI, there is a inline fuse located inside the microwave ion the power supply board. check for continuity. replace the fuse if necessary. if the fuse is OK, replace the power supply board.
Jun 01, 2009 | Kenmore 62702 Microwave Oven
Sharp R-9H56 Microwave convection oven
I have this model. Press clear then press Auto/Clock. Enter in the time eg 700 then press Auto/Clock again. The time should now be set
Jun 08, 2007 | Sharp R-1872 Convection/Microwave Oven
Microwave Ovens Logo
465 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
