SOURCE: Kenmore Gas Range Oven not Working Properly
greg, sounds like your needle valve is not seated. Remove the bottom drawer. Look back to the base of the burner where the shutter air adjustment is. Right under there is the valve which should have a 1/2 inch or 7/16 nut. (I Forgot what size). Turn this nut clockwise until the flame is adjusted to the correct size, should be a nice blue flame. The nut maybe hard to turn because you are seating the needle. Catriver..post back
SOURCE: Gas stove : the broiler works but the bottom of
The igniter will glow red even when it does not get hot enough to open the gas valve. Replacing the igniter should take care of the problem.
SOURCE: Gas oven will not light.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Testimonial: "Thanks! I thought that it may be bad, but wasn't sure since it would glow red."
SOURCE: model fgf334bgwj gas range oven
When the ignitor glows brightly and the oven doesn't light it is
usually a defective ignitor. The way to know if the ignitor is good or
bad is to read the amp draw of the ignitor with an amp or watt meter.
The gas valve and the ignitor are wired in series and for the gas valve
to draw the current the ignitor has to draw 3.5-3.8 amps.If the ignitor is drawing 3.5-3.8 amps the new gas valve is defective. If it is drawing less amps the ignitor is defective.
