SOURCE: Adding a 8GB MICRO SD card to the Sansa e260
I read somewhere that a 4 GB Micro SD card is the largest you can put in the SanDisk Sansa E260 expansion slot. It's maximum capacity is 8 GB, with internal + external memory put together. This is from what I've read. Hope this helps.
SOURCE: problem with reading Sandisk 4gig hc micro sd card in my computer and laptop
Your device is probably not compatible with the more recent SDHC (High Capacity) memory card format. Newer equipment can handle both SDHC and SD. Check with the manual or website for your card reader and the laptop, to check if they can recognize it. None of our older cameras can use SDHC, but it works fine in my daughter's new Pentax.
SOURCE: Sandisk 4gb microSdhc wont read in computer
few computers nowadays read SDHC out of the box. you will need to purchase a SDHC reader that plugs into your USB port.
SOURCE: Can't formate a Sandisk micro sd hc
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format card
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
SOURCE: unlock SanDisk 32GB Ultra Backup USB 2.0 Flash Drive
Support IDE/SATA/USB Hard Drives memory cards USB Memory Drives
http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html
Windows Password Cleaner
Available in Live CD to run offline
This is a utility to blank the password of any user that has a valid local account on your Windows system.
You do not need to know the old password to blank the password.
hope this helps
