on PX650-PX659 error code 0x43
0x43
SCANNER
B Scanner/ADF FB PID lock error. Encoder failure. Tooth skip or improper tension of the timing belt. Gear crack. Cable or FFC disconnection. Motor driver failure. Main board failure.
Hi I have a similar problem with Epson px660, it does not complete the self test after powering on then it flashes all lights with a printer error of fatal code 0x71, can you assist me kindly. Best regards
You can go to printerclinic.com and download a reseter of epson l200 or l100 Possible password: printerclinic.blogspot.com Reseter of l100 and l200 are the same
Here's the instruction.. 1.extract files 2.click the adjustment program 3.click the particular adjustment mode 4.check the three box on the left side then click initialization 5.then off the printer then on again
Q:
Why are all the lights on the printer flashing?
A:
When all the lights flash, your printer
may have an internal error. Verify that all packing material has been
removed. Instructions for removing the packing material will be found on
a notice in the box. If the printer has not made any noises for more
than five minutes, turn off the printer. Open the cover and check for
any obstructions. Power on the printer to see if the error still occurs.
If the unit still gives an error, please contact the Epson Connection
for further assistance.
