How do I replace the inverter and LED driver on Samsung UN46EH5000FXZA? I have identified that as the problem using the flashlight test, and have the back cover off the TV.
TV screen just went black last night. Sounds works. Followed Shop Jimmy's flashlight test, and identified the problem, I think. Where can I get the parts to fix it, and how do I do it?
Chances are your LED backlights are bad and it's shutting down the inverter, without the proper test gear there isn't a way to test the strips without removing the panel to get at each strip but in 9 out of 10 sets we repair with the symptoms you're describing it turns out being bad lamps not the power board
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
{View the site in web view or by a desktop to see the search box. Mobile view has no search box.}
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
If you see a picture with the flashlight you can rule out the T-Con board. It's working. So the led driver board is the problem. TV Parts Universal TV Stands DLP Chips ShopJimmy Go here for replacement parts.
