SOURCE: which light bulb can I use Hoover Contour
Use a refrigerator rated bulb. If you go to a Harry's Homeower store look in the bulb section or in the appliance section take to old bulb with you to compare.
SOURCE: hoover contour fridge leaking
Your evaporator coils frost up in normal use
and every eight hours or so the entire unit shuts down and the defrost heater
comes on to melt the frost. This cycle last about 20 minutes. The melted frost
drips into a drain pan and through a drain tube to the drain tray under the
freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end
because it drains too slow because it's stopped up at the lower end in the
evaporator pan under the unit at the floor. It can get dust and mold in it.
Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing
it out with hot water and clorox may help.
Make sure it drains quick enough to prevent
refreezing. . The drain should be located below the evaporator coils on the
lower back of the freezer.
Testimonial: "thanks, all fixed!!"
SOURCE: Hoover Contour HE423UFL fridge freezer continually frosts over?
I am on my fourth timer for this problem. Seems to fix the problem each time. You must remove the big chunk of ice covering the drain hole before you operate the fridge with the new timer. The contacts in the timer get burnt due to arcing inside the switch. The heating element seems to always work ok, but if the element is no good the fridge will not defrost.
SOURCE: I have a hoover 505
Hi and welcome to FixYa, I am Kelly.
Open the freezer and locate the door / light switch. Depress the light switch plunger / actuator and make sure the light goes off and the evaporator fan comes ON. Light stays on and fan does not run = bad door switch.
Next look for signs of ice build up on the back access panel / evaporator coils. Ice block noted on coils and back access panel = evaporator fan problem or possible door switch problem.
Last open the fiberboard cover on the back of the unit and check for massive amounts of lint on the condenser coils and that the condenser fan is running. Blocked condenser coils or condenser fan not running will cause the chassis to be very warm to hot when touched.
If you do not find anything wrong by performing the steps above:
After a 2- 4 days look again for any signs of ice build up on the evaporator coils. If you note ice beginning to build up on the evaporator coils there is a problem with the automatic defrost circuit.
Possible automatic defrost failure causes:
1. Defrost Control
2. Defrost heater
3. Thermistor (if so equipped)
4. Defrost thermostat
That is pretty much it runs all the time but does not cool troubleshooting. You should find something out of the ordinary by following the steps above.
Thanks for choosing FixYa,
Kelly
