SOURCE: washing machine
Sounds like you may have a corrosion issue or water ingress, causing a short. Could be a corroded heater, water in the main control board, water in the pump motor - the list is endless. Most washers tend to run the pump to ensure drum is drained before starting the cycle, so it would be probable that the problem is in the pump area.
You don't say if the main switch is an RCD or an ELB. I presume it's an RCD.
The filter on your pump is probably clogged with lint and other stuff. Lift washer up a bit. You have to remove the bottom front panel, 3 screws. The panel will drop and come off. Drain off excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water or a wet vac. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in.
SOURCE: LG Washing Machine stops spinning in mid cycle
IE:
• Water supply is not adequate in
area.
• Water supply taps are not
completely open.
• Water inlet hose is bent.
• The filter of the inlet hose clogged.
Solution:
Check another tap in the house.
Fully open tap.
Straighten hose.
Check the filter of the inlet hose.
UE:
• Load is too small.
• Load is out of balance.
• The appliance has an imbalance
detection and correction system. If
individual heavy articles are loaded
(bath mat, bath robe, etc.) and the
imbalance is too great, after several
attempts to restart the spin cycle the
machine will stop and the error code
will be displayed.
Solution:
Add 1 or 2 similar items to help
balance the load.
Rearrange load to allow proper
spinning.
UE:
SOURCE: baumatic washer draining but not spinning
I had this problem, may be an easy fix if similar issue: Remove back cover. Take a look at the underneath the drum towards the right hand side. There may be a hook on a wire hanging there. If it is just hanging, there, it should be hooked onto a grey coloured lever, which has a hole on the edge of it. This is the drum brake which during the spin cycle releases the brake allowing the washer to spin. Hook the hook onto this grey lever through the hole. Replace the back cover. Test the machine with a towel or something, allow it to fill a little, then jump to the spin setting and see if it spins. Worth a shot, these are great machines.
Hi
Error code FH appears when No water is detected
entering machine or Pressure switch trip is not detected. If after 30 seconds
the control does not detect water entering machine and then valves will be
turned off and the error code will be displayed. Press PAUSE/CANCEL twice to
clear the display. If there is no water entering the unit then make sure that
the inlet valves are working fine. You may need to check the continuity at the
inlet valves. If the valves are fine then check whether inlet water hoses as
they might be plugged. Also check for inlet water screen at the valve. However,
if the water is entering into the washer then the Drain pump might not be
working. Also inspect the Pressure Switch hose whether it is in good condition
and properly connected to Tub and Pressure switch. Also check hoses for leak
and inspect the flow meter. Hope this helps...
Daniel
