I have tried holding the power and volume up .. googled for fixes.. but I cannot get into system menu to do a factory reset.. any help would be appreciated.
1. Power the device down by holding the power and volume up buttons until the screen turns off. Also, remove the SD card you might have inserted into the device.
2. When the device is powered off, hold the power and the volume up and down buttons simultaneously. When the Pandigital logo appears then, release the three buttons
3. Immediately again press all three of the power and volume buttons until the Pandigital logo appears again, then let go. The device then should display an image of a triangle with an Android robot and an exclamation point.
4. Once the Android triangle image appears tap and release the power and volume up and down buttons.
5. To navigate through the recovery use the volume down button until "Wipe data and cache" is highlighted.
6. Tap the power button to select "Wipe data and cache", you will then be asked to confirm you selection. Use the volume down button to highlight "Yes" then tap the power button to confirm.
7. Once the system has wiped the cache and data you will be directed back to the main menu of recovery mode. "Reboot system now" should be highlighted, if not use the volume down button to highlight this option.
8. Tap the power button to select "Reboot system now" once it has been highlighted.
9. After a few moments, the device will reboot. When it has fully powered up you will be directed to the device`s initial setup wizard. Please follow these prompts to reset your preferences.
10. Once you have completed the setup wizard your device will be as good as new.
SOURCE: Got ANDROID 7'' IS STUCK ON THE LOGO
Have you tried removing the battery completely as this can sometimes "reset" the device...cant hurt to try
Testimonial: "OKAY I NEVER THOUGHT I CAN ABLE TO OPEN IT, ILL TRY IF ITS POSSIBLE"
