When a compressor reaches set pressure, there should be a release of air from discharge hose
thru the
unloader. This release of air unloads the compressor head pressure. The
unloader is usually located within the pressure switch. Easy to check. Follow discharge hose from compressor head to tank. There should be a brass/steel
checkvalve at the tank. The
checkvalve allows air to enter tank, however not allow air to be released back into discharge hose. If this valve is leaking, air will be released from the
unloader constantly. Follow 1/4" tubing from
checkvalve to
unloader and listen for leaks. Repair as needed. If air is not leaking from
checkvalve then check
unloader mechanism with-in pressure switch. Parts are available at
www.toolpartsdirect.com Good luck
