0236 0407 0414. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order.Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box. http://electro-medical.blogspot.com/ http://remotesearch.blogspot.com/ http://electrohelponline.blogspot.com/
Codes to your device might be different.
Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Try to Google that model number with "manual" to locate the owner manual which will have a list of codes and also will explain if the remote can search for all codes possible for the unit.
You need the sheet that came with the remote. If the manufacturer's codes do not work with your ??, then you need a more modern remote. The codes must ALREADY be in the remote to be used. The code is part of the REMOTE. http://www.tvcodes.com/ may have the code for you.
I had trouble programing the living solutions giant remote - c17g0801.
But after many times serching I ran across a genius' resolution (maybe it was 2 genius') - Jumbo Remote: Make sure you have device turned on.
Hold the device button you want to program for 3 seconds & release.
Push & release the power button & the red light will remain lit.
Push the CHANNEL UP button over & over slowly until the device turns off.
I have a Universal Remote Control Model ATC-1311 Giant remote. I have lost the codes to and instuction book to. Can you tell me where to get at least the code for my T>V> Thank you
still cannot find codes
