Hi I am Amy, I simply purchase another Lexmark printers and confronting ink spillage problem,I looked in the google and I got some valuable locales and number like a href=http://printer-help-me.com/support-for-lexmark-printer Lexmark Support /a and make a call to Lexmark Customer Service these destinations are exceptionally useful yet I need more recommendations.
SOURCE: I purchased a printer from
Ask to speak to a Manager, if it's unopened they should take it back.
Geno
SOURCE: ink problems lexmark x2500 printer
lexmark ran out of ink replaced cartridge. still saying i am out of ink and wont print anything
SOURCE: Lexmark x4850 ink levels won't reset with new cartridge
Hi...
Silly question, but I have done this myself. Have you removed the tape from the bottom of the cartridge?
SOURCE: Is there a compatible ink cartridge for Versajette M400 printer?
Sam's Club sells print cartridges for the Versajette at a more reasonable price. I saw the ad sometime ago, so give it a try.
SOURCE: Change region code on my printer to except 02 ink instead of 363
I moved from the UK to the US with an hp 7310 all in one and also ran into the same problem. You need to call HP support for them to change the region of your printer to accept the locally available ink cartridges. A max of 3 changes is allowed, and as the previous poster has mentioned, if your printer is out of warranty they will try to sell you an extended warranty to "fix" the problem. Here is a link from baconvsprout detailing the problem and trying to get it fixed. http://www.baconvsprout.com/index.php?option=com_content&view=article&id=101:hp-customer-service-and-region-coded-printers&catid=35:sprout&Itemid=59
in short the best way to get around it is to get your cartridges refilled. In the US Office Max charges $10 for black which is about1/5 the price of the retail hp393 cartridge that I need to purchase from the UK. in my opinion I am going to avoid HP products from now on.
1. Look at the indicator light on your Lexmark printer.
You'll need to replace ink cartridges when the light flashes or turns red
instead of the standard green.
2. Purchase Lexmark ink cartridges. You can buy the brand
name or purchase a generic version that is compatible with your printer. You
can shop for low cost ink cartridges from ABC Ink.
3. Remove the old cartridges from your printer. Grip the
sides of the Lexmark ink cartridges and pull it out. Dispose of the ink
cartridges in a recycle program like the one at Staples or save the cartridges
for refill.
4. Install the new ink cartridges after removing the
protective tabs. Avoid touching the IC chip when installing the new Lexmark ink
cartridges. Replace the cover of the printer.
5. Allow the Lexmark printer to run a nozzle test. Print
several pages with the new ink cartridges to make sure you installed the ink
cartridges correctly. The indicator light should return to a solid green color.
do rate the solution if it helps
