I have 2,2 cu.feet inverter microwave oven. It keep shutting after 3 second. When I tried to cook on sensor mode it shut down after 10 second. It does not cook at all.
Your temperature sensor inside on the microwave need to rreplace. It maybe dirty or faulty. Bring your microwave to electronics technician to check it.
Hi, if it is an inverter microwave and the problem is cycling every 2-3 seconds, my experience is the magnetron has most likely gone short circuit and the inverter board is shutting down to protect itself and then restarting, hence your symptom.
DO NOT try to test this unless you are experienced with extra high voltages - the voltages present/stored in a microwave even when powered off can kill you.
Put
in time, push start and unit runs
for 2 seconds, relay clicks, unit goes off. Cook time on display goes
off and clock time comes back. Bad upper interlock switch and charred
connector
Otherwise, if
the digital programmer circuit / controller does not get a feedback
signal from the inverter for a period of 3 seconds, the controller will
stop the cook cycle.
That may be a loose connection in the wiring between the
inverter, magnetron, and/or control board, or maybe one of
those
components has failed.
Due to the lethal
voltages used and produced in inverters, I do not recommend that an
inexperienced person work on these.
You didn't mention your brand or model number, but I'll assume it's a
Panasonic since you posted this under a Panasonic category.
See if this describes
what's happening:
Put
connector
Otherwise, if
If
it stops after 7 seconds, it has a problem with the inverter. If it stops at 16
seconds and is a sensor model, it probably has a defective humidity
sensor.
If
it stops after 22 seconds, that means the controller has detected a
problem, usually a problem with the inverter,
controller, magnetron, or a bad connection from one or the
other.
Display codes H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
those
Due to the lethal
Put
connector
Otherwise, if
those
Due to the lethal
If
Due to the lethal
