Freezers Logo
g
gerard gonzales Posted on Mar 31, 2017
Haier freezer mod#11cm071pa need a key the lock.
I need some additional keys made for freezer locks
Sometimes the lock will have a number and you can order keys from a locksmith. If you have a key already as a pattern, you can get them cut, BUT you say you want 'additional LOCKS made'? You just buy replacements, or put a hasp and staple on the doors and buy a padlock..
https://www.google.com/search?q=everbilt+freezer+lock+replacement
Apr 08, 2022 • Freezers
1helpful
Where is controller knob on freezer
Brenda, haier freezer control quite often front lower right corner, some may be behind freezer by compressor, check the links to see if you can find your model and manual. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://image.haier.com/manual/southeastasia/haier/freezer/chestfreezer/201203/P020120309357074931017.pdf
Haier Freezer manuals
Haier Freezer controls Google Search
I need a replacement for the keys of my HAIER 7.3 FRREZER
what do the dial and buttons at the bottom to be set as.we dont have a manual?
1helpful
Why can't a Haier chest freezer be put in garage?
The only problem that you might have is with the coils and the flux capacitor. If you clean the coils, it should be fine.
I have ice buildup in the lower right hand side of the freezer in the back behind the baskets
Haier are a bad brand, the unit has cooling fin frost up and will not allow air to pass through the cooling plates, defrost the unit for 2 days with door open and restart, if all good after that, keep doing it, if not, its lost gas and needs the bin. Quality items deliver lengthy trouble free operation, sorry but I put Haier in the Daewoo class, Kelvinator or Westinghouse next time, its worth that little extra. Regards Russ
2answers
Lost manual and need to defrost
This is likely a manual defrost freezer, which means you have to remove the food, unplug the unit, and let the ice melt on its own. Do not, and i repeat, DO NOT poke the ice away from the walls. I guarantee if you poke the ice away from the wall, you'll poke a hole in the wall, and force yourself to buy a new freezer.
SLOWER IS SAFER. put some boiling water, in the pot, inside the freezer, or use a hair dryer.
Top Haier Freezers Experts
NOEL
NOEL
Rob Hill
Rob Hill
Are you a Haier Freezer Expert? Answer questions, earn points and help others
