SOURCE: lens cover stuck open
I recently had the lens cover stick partly open. There are 4 segments to the lens cover, and if we number them from the top, number 2 was not closing.
I gently flicked the segments a few times, in case there was a grain of dirt causing it to stick (although the camera has never been in a dirty or dusty environment). This caused the lens cover to close fully each time, but now it would not open fully, segment 1 would not open, although it would stay open if moved by finger.
Anyway, after a bit of fiddling, I got it working properly again. The way that the lens cover appears to work is that only segments 2 and 3 are pushed open or shut by springs, segments 1 and 4 are pushed open and shut by tiny tabs that catch on segments 2 and 3. If the segments somehow get pushed out of alignment, then they either bind (causing the cover not to shut), or they get disconnected (causing the cover not to open fully.
Now I am not sure exactly what I did to get the mechanism form the stuck open state to the not opening state, but from there the way to fix it is to:
-With the lens open...
- Hold segment 2 in the closed position with firm finger pressure (which will tend to push it towards the lens).
- Push segment 1 towards the open position until you can see that it has cleared the edge of segment 2.
- Lift segment 2 way from the lens so that it will rub past segment 1 as you...
- Move segment 1 to the open position.
- Repeat if necessary to get the technique right.
I can't provide any guarantees, and I am not about to repeat the excercise on my camera, but it was a lot easier than sending it off for repair.
SOURCE: Panasonic DMC-TZ1 Won't turn on
I have just had this problem - was about to take it to shop for a checkover when I held shutter button down and then turned on - viola - don't know if it was a fluke or what
SOURCE: The photos aren't downloading from
Make sure you have the Mac driver for your camera. Install the Mac driver that came with the CD. Try to use a different USB cable. You can also try to isolate the problem by plugging your camera to a Windows OS computer like windows xp and vista.
SOURCE: Its a Panasonic DMC-TZ3. all
Hello
If you can view the pictures previously taken with the camera on the camera LCD, but the new photos just come out black, this is most probably a blown ccd.
This is a expensive component to replace, and you will also need specialized equipment to do this yourself.
I would suggest that you take your camera to your nearest repair shop and let them test the ccd.
Hope this can be of help.
Kind regards
Andrea
