There's a wire ring, with a spring for tension, that holds the inner rubber seal in place just in side the door on the Nexxt 100 washer. This ring has come off, and I cannot get it back on. Any sugesstions on how to get it back on? Everything I have tried keeps pulling the rubber seal off of the holding points.
Bosch Nexxt 100 Series WFMC1001UC Front Load Washer how to put back on wire ring, with a spring for tension, that holds the inner rubber seal in place.
This video will show you how to change a door seal on this Bosch front loader washing machine and also how to get back on, the metal ring around the seal.
we have all bosch repairs in our channel.
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Loosen the screw (mine has one) and slip it over the hump and into the groove. Don't overtighten. IF all you have is a spring, slip the top of the ring over and into the groove and slowly work the remainder over and down by holding the spring part apart until you get the ring clamp as far over as possible. If you have some silicone spray, this will help.
Regards, --W/D--
This
article shows step by step photo instructions on how to replace the
door boot seal of a common GE brand front load washing machine.
The washing machine in this example is the GE and the door boot seal
j
