The spray nozzels just bubble the water out. will not spray. if i turn it off it will spray for about 3 cycles then stars bubbling.
Scotsman ice machine model # cm250ae-1c makes very little wet ice & alot of water comes out of drain line at times
Make sure the curtain is not torn and there are no leaks from the resivoir. If ok check to make sure you have enough water pressure to the machine. Make sure you have enough water passing through the valve during harvest cycle. To check... turn the timer cam to harvest cycle. Water should come in quickly behind the curtain on the right side and the timer should advance three minutes to freeze portion of cycle and stop running. Water should spray and form ice for approximately 25min. Then the timer advances for 5 minutes into harvest cycle and it refills with water again.
