Question about Kenmore Freezers
My reset button on my chest Ken more freezer keeps going off. Push reset it stops then hours later goes off again
  • Kenmore Master
  • 10,543 Answers
There is an excessive current draw. The compressor is the first thing to check, then the inside and outside fan motors. If there is a strip defrost heater element that has gone bad, that will do it too.
Posted on Mar 28, 2017
6ya staff
SOURCE:
I have a bush chest freezer CF-143GB. Recently the compressor runs continually. It can be stopped by turning the thermostat right down. A little while later and having reset the temp control it restar
Sounds like it has an auto shutoff if issues arise
Try clearing all vents - inside (make sure vents not covered) and out (vacuum - the coil areas)
Sep 11, 2014 | Freezers
Chest freezer suddenly stops working then will start again later
This is normal if your freezer is in good working condition. If your compressor runs constantly then there is a problem. Once the unit reaches the set temperature the compressor shuts down. The set temperature should be between -2 & +2 degree F. The set temperature also depends on how full the freezer is. There will be a time when the freezer like refrigerators will shut down. This is relative to the term, "Frost Free". The unit will shut down for about 10 minutes. This occurs ever 8-10 hours. The heater turns on to defrost your freezer coil. It sounds like you are in good shape.
Apr 18, 2014 | Westinghouse Freezers
My Avanti CF142 chest freezer won't work on normal setting. It will work on Quick freeze so I know the compressor is good. Any ideas why it won't work on normal setting. The green light won&
Sounds like your control switch is going bad. Good thing you have the quick freeze button. You may want to go ahead and replace it. The whole thing will go out soon. This is something you can replace yourself.
Jan 27, 2013 | Avanti 5.3 cu. ft. / 150 liter Chest...
GE chest type freezer buzzer going off
If you have a fast freeze button try that and see if the alarm goes off within a few hours. It bypasses the thermostat switch. Check condenser clean etc but be prepared for compressor failure
May 19, 2012 | GE Freezers
Electricity went out & audible alarm is going off. Would like to know if there is a reset button for this or will it reset itself when temp goes back to normal.
Will stop on it's own when it get cold again, but most generally have a manual alarm shut off (on back, near hinge on older models).
Apr 28, 2011 | GE 14.8 cu. ft. General Electric Chest...
Compressor click
Possibly. However it sounds like the compressor is running hot which could be the relay assembly sticking with the start windings in the circuit.
Eric
Jan 24, 2010 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Problem with Maytag Chest Freezer model MQC1557aew.
First make sure than the condensing coil in the freezer is clean of dust and dirt(it is behind the grill vent in the bottom side of the freezer where the compresor is) If it is clough brush the dirt off after you unplugit.When is clean wait a few minutes ,5, and plugg it back at the GFI outlet and see if work If still tripped the outlet you may have to replace it.
Apr 04, 2009 | Maytag 14.8 cu. ft. / 419 liter Chest...
Frigidaire Chest 5 cu ft Making Fan noise & will not turn on...6 yrs old.
at 6 years old it certainly aint new!
from what you describe, sounds like a compressor fault
Oct 09, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Freezers Logo
143 people viewed this question
Top Kenmore Freezers Experts
John Tripp
John Tripp
Felizardo Erilla
Felizardo Erilla
PNiss
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
