Sony BRAVIA KDL-32S2010 32 in. LCD Television Logo
J
John Grimes Posted on Mar 28, 2017
Can a Sony bravia kdl-32s2010 be fitted to the wall on a bracket as it looks like all the connections at the back would be behind the bracket plate if one was fitted
The scart and hdmi connections are at the back where it looks like a fixing bracket would cover it.
Can a sony bravia kdl-w40a12u be put on a wall thanks
You need to use GOOD WALL BRACKETS which can hold the weight of the TV.
Also the mounting on the wall must be firm with good foundation tower bolts.
please check on the links below for some tips and ideas on wall brackets.:
TV Wall brackets: http://www.regencyproducts.co.uk/
http://www.espares.co.uk/parts/tv-and-audio/lcd/plasma-brackets/p/1459
Kdl-32s2010 .... after 1 hour, screen goes blank. I can get to the menu and switch to digital then back to analog and it works fine for another hour. it is hooked up through a regular cable to a sattelite...
The sattelite box have issues,tries unplug,replug the box back like about an hour later for it to reboot and resetting and upgrading it softwares.This tv problems switching modes to digital and to analog again back and forth should be solved.Still happening the box have problems,call ur sattelite provider change the reciever box.
3helpful
Vertical Lines on Sony Bravia TV.
I'm afraid, its problem of LCD Panel (screen).
LCD Panel replacement is only solution for this problem and will cost you 70% of TV price, please contact nearest Sony service center for LCD Panel replacement.
1helpful
How do I remove the stand of the Sony Bravia XBR KDL-V40XBR1 so i can wall-mount the tv?
you have to lay the tv on it's front on something to protect it from being damaged.on the back you'll see where the base joins the bottom of the display, this needs to be unscrewed and a wall bracket screwed in instead.
Trouble mounting cantilever wall mount bracket to Sony TV
Finally figured out the correct arrangement or configuration through trial and error (and my wife's puzzle solving ability). It sure wasn't clear in the instructions, and I could not get the needed information from the website of either the manufacturer of wall mount system or TV...a little frustrating, but perseverance paid off. Given the price of the wall mount, I would think they could do a better job.
Sony Bravia 40" LCD TV Stand
There is a slotted area on the bottom of the unit and the bracket on the stand slides over top of it. There should have been four screws that came with the packaging that fit in the four locations in the lower center of the cabinet back that secures the unit to the Stand.
I hope this helps,
Skyassoc
Will A Sony Bravia KDL 32s2010 TV purchased in the
This TV will work in Australia as its multi system and auto-power TV.
Blue screen, have AUDIO ON ALL CHANNELS!
Make sure video cable is connected on right socket. for instance AV1. test cable box on other tv to see if it is transmiiiting picture. If so make sure your tv is tuned to cable box if using RF cable or on slected av mode where av cable is connected
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
