Question about Dell Computers & Internet
How to insert a num lock key in Dell Latitude330?
  • tomar33 Apr 16, 2017
    Hi Usman Munir, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    do you mean turn on the number lock key, which is found in the bios settings?
6ya staff
SOURCE:
Thx_nb
  • 242 Answers
SOURCE: can't get num lock to work on Dell Inspiron 6400
The 5th key from the right on the top row of your keyboard should is the Num Lock Key...
Posted on Dec 12, 2008
Geekman
Chris Hingee
  • 32281 Answers
SOURCE: Num Lock key must be off. I can't log in using my 4 digit code. How do I turn on the Num Lock key? It is not marked.
It is one of the function keys, it will have a keypad symbol on it.
On my Toshiba it is the F11 key.
Try the Fn key + F11 key to enable the numbers, press the combination of key again to turn off Num Lock
Posted on May 01, 2009
Kawawa Chitiya
  • 119 Answers
SOURCE: Letters are num locked. pushing num lock key does not resolve
Number lock, a situation where numbers instead of letters are typed is as a result of the digital lock being active. to deactivate pressing the Fn+Numlk or Fn + Shift +Numlk key combinatioins
Posted on Jun 18, 2009
NinaE
  • 3278 Answers
SOURCE: dell inspiron 9400 not booting
Hello.
The most common reasons are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Posted on Jan 28, 2011
Leon Robinson
  • 747 Answers
SOURCE: DELL n4030 num lock problem.
maybe its the scroll lock key.
Posted on Feb 02, 2011
I'm trying to use the num lock to input numbers, but the function doesn't work unless I have num lock activated and also have the fn key constantly pressed. How can I fix this problem? Once I activate...
On some models, pressing Fn and F4 key will disable/enable Num lock on latitude.
On some other Dell laptops, a BIOS setup menu selection must be made when turning on the laptop to enable it to work.
Dec 26, 2017 | Dell Latitude 2110 Notebook
I cannot find the num lock on my dell studio laptop...can you help?
Normally the num lock is marked as num Lk which is placed next to the F12 keys in the top row.
So check this out ..... This is so in my Dell vostro
Sep 27, 2010 | Dell Studio 15 Laptop
I have a dell keyboard and the numbers are locked and i can not find a numbers lock key
The NUM LOCK key *IS* on the keyboard.
Press the BLUE-coloured 'FN' key while pressing the BLUE-coloured 'NUM LOCK' key.
Aug 20, 2010 | Dell OW7658 (J4624SK8115RT7D50) Keyboard
There is no key for numlock on my Dell studio 15 keyboard
The num lock key is labeled as 'Num Lk' on the Dell Studio 15 keyboard. It is located above the =/+ key next to backspace.
To activate num lock, you cannot just press the button. You have to make sure the num lock light is on and then hold down Fn while using the numpad.
Hope this helps,
Tiger720
Sep 02, 2009 | Dell Studio 15 Laptop
Number 9 inside a lock symbol on the keyboard and computer unresponsive
press num lock /num LK/scroll Lk.Find any of those key on your keyboard.it solve your problem.If .in Dell Latitude D600 the num lock/num Lk/scroll Lk is above F11 key.
  • after solve it,don't forget to visit me here
Jun 10, 2009 | Dell 0Y3740 Keyboard
Num Lock Light Wont Work
the led either burned or became un-soldered from the board. the labor to fix it is not worth it in my opinion un-less you can do it yourself.
Jun 04, 2009 | Dell Inspiron 6000 Notebook
Key pad doe not work
This means the number lock is on - in the upper right hand corner of the keyboard is a series of 4 keys.  Far right is delete, then (from the right) insert, Prnt Scrn, and Num Lk.  Hit the Num Lk key, and the number 9 with the padlock should shut off.  Your keyboard should now work normally.
Any more problems, let me know!
May 26, 2009 | Dell Inspiron XPS Gaming Mouse Pad KU170
Can't get num lock to work on Dell Inspiron 6400
Dec 08, 2008 | Dell Inspiron 6400 Notebook
Fn key on keyboard seemed stuck
hit shift and "Num Lk" at the same time. Num Lk is abov the F11 button on some Dell keyboards.
Tony Nguyen From Pasadena, CA
www.connectionzpcrepair.com
Aug 06, 2008 | Dell Latitude CPX Notebook
Open Questions:
Dell Printer@^+[1]=855-221-4867@&@tech Support Phone Number Tech Support Number Dell Printer Tech Support Number+1(855) 221-4867 time to gayo independently owned and operated all kind of technical support. There are a long series of Dell Printer s including latest technology and affordable price. Dell Printer produce All-In-One with basic printinG copying and scanning functions. Antivirus s are compact and lightweight.Dell Printer Tech Support Number 1(855)221-4867 is an independently owned and operated all kind of technical support. There are a long series of Dell Printer s including latest technology and affordable price. Dell Printer produce All-In-One with basic printinG copying and scanning functions. Antivirus sare compact and lightweight.Dell Printer Tech Support Number 1(855)221-4867 is an independently owned and operated all kind of technical support. There are a long series of Dell Printer s including latest technology and affordable price. Dell Printer produce All-In-One with basic printinG copying and scanning functions. Antivirus s are compact and lightweight. Dell Printer Tech Support Number 1(855)221-4867 is an independently owned and operated all kind of Tech support. There are a long series of Dell Printer s including latest technology and affordable price. Dell Printer produce All-In-One with basic printinG copying and Dell Printer Tech Support Number 1(855)221-4867 is an independently owned and operated all kind of Tech support. There are a long series of Dell Printer s including latest technology and affordable price. Dell Printer produce All-In-One with basic printinG copying and scanning functions. s are compact and lightweight.Dell Printer Tech Support Number 1(855)221-4867 is an independently owned and operated all kind of Tech support. There are a long series of Dell Printer s including latest technology and affordable price. Dell Printer produce All-In-One with basic printinG copying and scanning functions. s are compact and lightweight.anning functions. s are compact and lightweight dell printer configuration web tool dell printer default password dell printer document stuck in queue dell printer drivers dell printer drivers for mac dell printer error 004-321 dell printer error 009-340 dell printer error 016-302 dell printer error 016-302 dell printer error 0502 dell printer error 077-900 dell printer error 1203 dell printer error 900.57 dell printer error codes dell printer filter failed dell printer firmware error 900.00 dell printer firmware error 900.57 dell printer fuser error dell printer goes offline dell printer goes offline windows 7 dell printer goes to sleep mode dell printer green flashing light dell printer grinding noise dell printer installation dell printer jam problem dell printer job stuck in queue dell printer keeps calibrating dell printer keeps going offline dell printer keeps initializing dell printer keeps jamming dell printer keeps printing same document dell printer keeps saying downloading application list dell printer keeps saying left cartridge incorrect dell printer keeps saying offline dell printer keeps saying out of paper dell printer keeps saying paper jam dell printer network setup dell printer not communicating with computer dell printer not printing dell printer not printing black ink dell printer not printing color dell printer not recognizing cartridge dell printer not scanning dell printer not working with windows 7 dell printer not working with windows 8 dell printer not working with windows 8.1 dell printer offline dell printer only prints one page dell printer out of paper error dell printer pc life warning dell printer problems dell printer setup wireless dell printer tech support number dell printer there is a problem with the printhead dell printer troubleshooting dell printer will not print dell printer wireless setup dell printer wireless setup utility dell printer won't print dell printer won't print black
Jul 23, 2019 | Dell Computers & Internet
Computers & Internet Logo
98 people viewed this question
Ekse
Clive
Clive
Alun Cox
