HP LaserJet Pro 400 M401DN Laser Printer Logo
Nisar Ahmad Posted on Mar 28, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is 59.A0 Error in hp laserjet pro 400 printer?
Jim Keysor
Level 2:
Sergeant:
  • Expert 331 Answers
  • Posted on Mar 28, 2017
Jim Keysor
Expert
Level 2:
Sergeant:
Answers
331
Questions
Helped
83799
Points
605
This is usually a motor code, turn off, unplug wait 2 to 3 minutes plug in and try, may work good luck
Hp Laserjet pro 400 m401dw printer 59.A0 error
https://printcopy.info/?l=en&mod=erc&brand=HP&model=LaserJet%20M401dw%20Pro%20400&code=41.3000
Google m401dw Error codes
  • 59.X Error
  • Description:The product has experienced a problem with one of the motors.
  • Remedy:Turn the product power off, wait at least 30 seconds, and then turn the product power on and wait for it to initialize. If you are using a surge protector, remove it. Plug the product directly into the wall socket. Turn the product power on.
Hp laser jet pro 400 m401 printer 59.A0 error
You have a problema related with the Fuser Unit, you may try to replace the Heating elemento or replace the entire Fuser
My HP LaserJet Pro 400 M401n is showing a 59.A0 error and making weird sounds. How can I fix this?
This 59 error points to main motor or fuser drive gear motor. Before giving up, take out toner and close the top without the toner in the printer.Next, replace with a used toner or one you have as a back up. A lot of times it points to a motor that gets stalled by the drum that resides in the toner cartridge that is tight to turn. Check this, especially if this occurred after replacing the toner.
did you read the HP page, on your M401 page.
and read the trouble shooting guide there,
all error codes are there, to read 24./7.
or ask here and they will point to the page. for you.
https://h30434.www3.hp.com/
What is Error Code:59.A0 for Hp laser jet 400 M401d?
59 error indicates a main motor failure. This if often caused by a jammed cartridge, so trying a new toner cartridge would be your first step to trouble shoot this.
How to fix 59.A0 AND noise from the fuser unit on hp color laserjet 9500mfp
I would suggest the drum unit or the toner cartridge was not reassembled correctly. Do it again.
What is Error Code:59.A0 for Hp laserjet 400 M401d?
A main motor error occurred. X description: 0 = Motor error 1 = Motor startup error 2 = Motor rotation errorA main motor error occurred. X description: 0 = Motor error 1 = Motor startup error 2 = Motor rotation error HP LaserJet Error Codes 50 59 Looks like a motor error check the fuser unit and drum are seated properly.
k24674
Grand Canyon Tech
Grand Canyon Tech
