SOURCE: Reset Admin Password on used computer.
If u want to reset admin password withuout lose nothing download this program burn it to cd and start pc from CD-ROM.It is veru easy way
Download
http://rapidshare.com/files/73232969/ERD_Commander_2007.exe
SOURCE: Dell Optiplex GX260 desktop-how to reset factory settings in BIOS
sir try to remove the pill battery its in the inside of ur box that return it that might give an error said that u shud configure again ur time and date but that is easy but taht will increase teh speed and gives a reset to full factory defaults
SOURCE: install windows xp pro
Hi
My is working , i have same dell server 1600 , i download the driver from LSI website here is the link
http://lsi.com/storage_home/products_home/host_bus_adapters/scsi_hbas/lsiu320/index.html?remote=1&locale=EN
you just need u320 scsi driver for server 1600sc
download XP driver 32 bit it will work
victor
SOURCE: Compaq Presario SG3430IL Desktop PC display does not work with windows xp sp2 and vista
Kindly get me the drivers as i have installed xp in my compaq system. and i want drivers for that
SOURCE: Forgot username for admin acc in windows xp
Forgetting your Windows administrator login password. With no way to get into the system, you can’t even perform basic maintenance, let alone a thorough tune-up. Formatting is always an option, but we consider that a last resort. (Plus, guess who’s going to have to help reinstall all the programs lost after a wipe?) But all hope is not lost. There are a few ways to actually retrieve a lost Windows account password. Read on, and we’ll show you the light.
1st Method:
The first thing which you check if you forget login password. When we install Windows, it automatically creates an account "Administrator" and sets its password to blank. So if you have forget your user account password then try this:
Start system and when you see Windows Welcome screen / Login screen, press ctrl+alt+del keys twice and it'll show Classic Login box. Now type "Administrator" (without quotes) in Username and leave Password field blank. Now press Enter and you should be able to log in Windows.
Now you can reset your account password from "Control Panel -> User Accounts".
Same thing can be done using Safe Mode. In Safe Mode Windows will show this in-built Administrator account in Login screen.
2th Method:
There are a lot of Windows password revealers and crackers available, but we’ve found that Windows Password Recovery Tool is the most effective.:
Windows Password Recovery Tool is one of the easiest password recovery tools to use. It allows you to reset a user account password, including the Administrator password. It is also a relatively small download.
Windows Password Recovery Tool Service: http://www.windowspasswordsrecovery.com
Click start run type cmd press Enter
black screen should open DOS mode
this will vary depending on your operating system
type in net user username
For eg. If you want to change administrator password , type net user Administrator
it will prompt you to enter the new password
enter the new password and the password is changed
hope this helps
