Computers & Internet Logo
B
Ben Buey Posted on Mar 27, 2017
Peugeot 207 sportium. Clarion NX501 Satelite Navigation option has stopped working.
Nothing happens when you press the Navigation option on the screen and its not lit up, all other options work and the words are lit up but not this. Removed and refitted SD card, still nothing. Any ideas please?
1 Related Answer
Anonymous
  • 689 Answers
  • Posted on Nov 06, 2012
SOURCE: I have a clarion NX501 multimedia system in a peugeot 207 sportium. How do I turn up the rear speakers? just read a thread that suggests there may not be rear speakers!!!!!
Turn the fader control .To the rear speakers.
Everything works except the volume why
Mute Button
https://www.google.com/search?q=clarion+nx501+mute+button&
NX501E NZ501E
Clarion Global https://www.clarion.com > MungoBlobs > NX501... PDF • Press this button more than 1 second to stop video and audio media. [MUTE] Button. • Mute or Unmute the speaker. • The symbol on upper right area of the ...
123 pages
Switching On, Off Or Mute; Audio Source Selection; ...
ManualsLib https://www.manualslib.com > ... > User manual Press the button again to cancel the mute function. ... by turning off the vehicle ignition and removing the vehicle ignition key. Audio source selection. AM/FM.
NX501A
Clarion Global https://www.clarion.com > NX501A_ENG PDF • Press this button more than 1 second to stop video and audio media. [MUTE] Button. • Mute or Unmute the speaker. • The symbol on upper right area of the ...
138 pages
Functions Of Remote Control Buttons - Clarion Manuals
ManualsLib https://www.manualslib.com > manual > Clarion-Nx501 Functions Of Remote Control Buttons - Clarion NX501 Owner's Manual & Installation Manual ... and audio media. [MUTE] Button. • Mute or Unmute the speaker. • The .
Sat nav not responding on touch screen peugeot 207 sportium
If the sat nav is not responding to touch on the touch screen of your Peugeot 207 Sportium, there are a few things you can try: Check if the screen is clean: Sometimes, the touch screen may not work if there is dirt or debris on it. Use a clean and soft cloth to wipe the screen. Restart the system: Try restarting the sat nav system by turning off the car and turning it back on again. Check the settings: Check if the touch screen settings are correct. In some cases, the touch screen may be turned off in the settings, so make sure it is turned on. Update the software: If the sat nav software is outdated, it may not work properly. Check for any available updates and install them. If none of these steps work, it may be a hardware issue and you may need to take the car to a mechanic or Peugeot dealer to diagnose and fix the problem.
My Peugeot 207 Sportium Sat Nav NX501 has stopped working , when you touch the Sat Nav function on screen it just goes to a blank screen - any advice?
If you're finding it difficult to service/repair your car, get one of those online manuals. You'll not have to wait for others to answer, or rely on mechanics and all. Plus i know a website that has very good manuals online, without expiry i.e. for lifetime.
www.reliable-store.com
My Peugeot Sportium Sat nav has stopped working when you press the sat nav on screen function it just goes blank. any advice?
Why did the screen stop displaying anything?
No idea.
Recommend contacting a local car audio professional or Clarion customer support directly here:
https://clarion.com/xe/en/user-support/inquiry/contactus
1helpful
2answers
I have a Clarion 501NX. The Navigation will not work. Was a micro chip supposed to come with it. I looked in the door and no chip was inserted in it. The unit came with a motorhome that I just bought
The small slot is for a MicroSD (storage) card which is not required to be used for operation. I have no experience with this model but here is the link to the 160-page manual which you likely don't have. This may provide enough detail to resolve your problem.
Download manual
I have an error message coming up on my Clarion NX501 in dash navigation system "Out of Memery" "Requested: 2416555267" "Cache : 0" Navigation will not come up at all....
take the navi card out and stick it in your computer then partition it then update it online with new navi software reinstall the card this should fix your problem
4helpful
2answers
I have a clarion nx501. The micro sd card that has the navigation on it is corrupted. the guys at clarion said that they can't cover this under warranty. please tell me what my options are. i heard...
Please read my post here: http://community.crutchfield.com/forums/p/22187/251957.aspx (pasted below).
I hope you bought your unit at a Clarion dealer....
Hi, (Team Crutchfield - please add this to your knowledg-base.)
I'm on my third NX501 (could have been the fourth if not for working directly with Clarion).
The SD Card corruption causes both loss of Navigation and intermittent Sirius start up (it'll never acquire signal).
Your unit needs to use the exact micro sd card it came with forever (it has a permanent serial number).
You have two choices:
1. Get Crutchfield to replace the unit
2. Call Clarion (I suggest this rather than ripping your dash apart over and over).
Here's what to do. Contact:
Ben Kwan
Customer Service Technical Representative
Clarion Corporation of America
800-347-8667 ext 4342
Direct Line: 310-217-4342
Fax: 310-217-4243
Ben will have you send your microsd and rebuild it for you and return it (likely with the firmware upgrade that addresses this issues on another microsd that can also be found here: http://clarion.com/ca/en/support/navigation_updates/NX501Fupdate/index.html).
While you're at it, update the Bluetooth firmware too: http://www.clarion.com/us/en/support/software/NX501/index.html
Once you get the card returned (THIS IS HUGELY IMPORTANT - EVERYONE WITH A Clarion NX501 SHOULD DO THIS!!!), back it up using Naviextras toolbox (the program clarion uses for map updates). You can get it here: https://clarion.naviextras.com/shop/portal/downloads
Once you follow these steps, barring your micosd physically or logically self destructing, you'll have an NX501 that's nearly problem free and backed up just in case that unfortunate corruption reoccurs.
Of Note: Ensure you insert the microsd card with the contacts facing up and do not force anything.
I'm extremely confident this will make a world of difference for you (and anyone suffering the microsd corruption of the Clarion NX501).
Regards,
Marc (mshmovie)
Top Option Computers & Internet Experts
 Mikey
Mikey
Larry Ng
Larry Ng
ADMIN Eric
ADMIN Eric
Are you an Option Computer and Internet Expert? Answer questions, earn points and help others
